When I wiggle my phone it rattles. Like a piece of something is loose inside. Weird problem, I know. It works totally fine though. Its just worrisome to have my phone rattle.
Most likely just the vibrator inside. See also:
Oh okay. I think the Camera Lens and vibrator are causing it. Now I know. Thank you!
maybe a silly question but for 6 months now, i ear a weird noise like a little spare part detached moving inside my fairphone. For the moment, it doesn’t affect the functionning of my phone but juste to know if I need to fix it to avoid worsening?
Thanks
