MMS issue: info?
Seems that I cannot send MMS with FP2. I have an account with Ello Mobile (Belgium) and have been trying for days to enter the right data, to no avail. Anyone have a clue?
Cheers,
Sven
Have look here: MMS setup for Luxembourg
There’s no real solution yet, but maybe some inspiration…
In another topic I read that your MMS problem isn’t solved yet. I found this: http://www.ello-mobile.be/nl/help/veelgestelde-vragen/kan-ik-via-jullie-netwerk-gebruik-maken-van-mms.aspx . I don’t read Dutch very well, but as far as I understand it, you either activate MMS during the ordering process or, if you already are a client, by writing to the email address mentioned in this article.
Hi Irina, oh yes, I have done that already. Great support from Ello, but alas, to no avail.
My German provider Congstar doesn’t allow MMS over wifi, so I have to be connected to the mobile internet in order to send or recieve MMS. Could this be your case as well?
Hey Irini, thanks,
I’ll give it a try, but normally wi-fi should not be a problem here, there is no restriction.
Cheers,
Sven
