Hi folks,
Since the day I received my FP5, I’m still not able to update the system software (see Can't use updater for eOS 2.6.3).
As you can see in the linked thread, I tried reinstalling, but no luck.
Yesterday I tried to install LineageOS, but this didn’t work, so I tried CalyxOS, which worked, but I had to change the install script:
Instead of flashing xbl_a and xbl_b images, I had to remove the b-slots, since it always gave the error: Partition not found.
I had a similar error when installing e/OS. The system updater of CalyxOS is also not working, so this is probably related.
Does anyone know, how I can restore the xbl_b and xbl_config_b partitions?
Did you ask in the e/OS forum? And when you bought it from Murena, contact their support to get it fixed, as it seems to be from the beginning and rather an intlation error at their end?
No, I didn’t asked in the e/OS forum, since it’s not (solely) an e/OS specific problem, but more a general problem with my phone apparently.
I’m hoping that some dev, or someone with a deeper knowledge regarding android/FP5 partitioning will read this thread and gives me some guidance
Also I bought the phone directly from Fairphone, so I’ll probably contact the support, but we all know this will take ages
While trying to fix things (see initial issue), I completely bricked my fairphone
I should have known better, but I was a bit to eager to fix it myself. The phone is still recognized by firmware flashing software, but without the non-available firmware files, I’m stuck with the support.
It’s been more than 3 month now, without any answer from support. The initial ticket was marked as solved, but my phone is still just a brick, so I opened a new one, which is still unanswered.
I don’t mind paying the fee for re-flashing the firmware, but without an answer I can’t send it in.
Which leads me to my question: Is there any other way to get my phone to the repair center, or is there any other place, which can re-flash the firmware?
Would be nice to use my FP5 again, instead of the old phone of my friend
Painful to read about your long wait for support reply.
I don’t know about re-flashing but I would definitely recommend trying the chat online tomorrow (10-12 Amsterdam time), insisting on talking to a human and implying that you have not yet registered the ticket.
I checked and it looks like a CS team member is already working on your case but due to high workload, it might take a bit longer. Thank you for your patience, I am sure you will get a response soon from our support team.
Sorry, forgot to update my post.
Don’t know if someone from support read my post, but the next day or so, they answered and I got the UPS return label to send the phone in <3
Hopefully they be able to fix it, but I’m hopeful after doing some research,
The repair went smooth and was very quick (8 days including shipping) and everything works as expected!
So this thread can be closed. Thanks for the support and tips from all participants <3
