Minimum volume is too loud
Hi. I’ve noticed over the few years I’ve had my FP5 that the minimum volume on a lot of different settings is way too loud. I searched around the forums a bit and can see it’s an issue that others have faced before.
For example, I like to take phone calls on speakerphone. However, if I’m in an environment that’s even slightly quiet, the minimum speaker volume becomes too loud.
The exact same goes for holding the phone up to your head during regular handset style phone calls. Sometimes I have to hold it a distance away from my head in quiet surrounds. It’s even worse if the person on the other end of the call is in a noisy place.
That said however, it’s odd that this terrible minimum behaviour isn’t reflected across all volumes in the phone. The media volume (e.g. when playing a song) has a perfectly normal and reasonable minimum. It also has way finer adjustment, with a lot more notches than call or notification volume.
I tried the “absolute volume” developer setting, but that’s only for Bluetooth. Even if it did work, users shouldn’t need to dig into those settings just to have normal phone functionality anyway.
So I ask this. Fairphone, please lower the minimum volume of call earpiece, speakerphone, ring, notification and alarm volume. Please then make them more granular to account for the gap between volume steps increasing after widening the volume range
I don’t know anything about Android development, but I can’t imagine this would be a difficult change to make. It might even be really helpful to people out there who use a Fairphone and have sensory issues like hypersensitivity.
This is a users forum. Fairphone doesn’t read here.
You can contact Fairphone through the Support at the website of Fairphone.
Same experience here, music volume was fine but everything else (calls, notifications, ring) got stuck too loud with nowhere lower to go. A small open-source app fixed it for me: it adds attenuation steps below the normal minimum across whatever is playing, through a floating dial, no root needed. Does not touch the physical volume buttons. Disclosure, it is my own app, and since today the Play version gives seven days of everything, then a one-time purchase; the F-Droid build is free and complete: https://play.google.com/store/apps/details?id=granularvolume.com&referrer=utm_source%3Dfairphone%26utm_medium%3Dforum%26utm_campaign%3Dintercept
If they really don’t read posts in this forum it means they have no respect and gratefulness for all the trustful users paying more money for fairer phone. After all I read about the service of FP I guess I won’t buy it again. (FP5-User)
This forum was set up specifically for users.
This is also stated in the information provided when you create an account.
Welcome to the Fairphone forum!
Join the community for a fairer electronics industry.
This user forum is not an official Fairphone support channel.
So I don’t understand why you’re saying that Fairphone isn’t showing any respect or gratefulness.
If you’d like to get in touch with Fairphone, there’s a support service available, including via chat if you prefer.
Update from the developer, since I can no longer edit my post above: the app is now available only through Google Play, with seven free days of the full app and then a one-time unlock. It is still open source (GPL-3.0), with no root, no ads and no accounts. One limit worth knowing: app calls such as WhatsApp are lowered, regular phone calls are not.
