MicroSD not writable or strange deletions later on
Hi Forum,
I am using the MicroSD as external formatted.
Additionally, I am using it mainly to sync folder with syncthing content.
The existing Folders are running smoothly. However, I created a new one a few days ago and started using it. After some time it disappeard like someone deleted it. Same behaviour after a restart.
The stock folder Android, Movies, Music and Pictures are not affected and remain and are in use.
Does anybody has experience with that problem?
Best regards.
Do write operations to the existing folders still work?
Newly written files/folders disappearing to me sound like the SD card is close to breaking completely. Had that a couple of times over the years and that is the way it begins. If that’s the case, only a fresh card will help.
Hi Ingo,
thank you for your suggestion. Of course, I didn’t see the obvious solution; instead, I immediately thought of complicated ones… I checked the MicroSD in my Computer and I even wasn’t able to format it. I ordered a new one now.
Kind regards and take care.
