Microphone 1 & 2 doesn't work anymore
Hello everyone,
Since 3 days, microphone 1 & 2 (top and bottom) doesn’t work anymore on my Fairphone 5. The microphone 3 at the left side works well when I put on the loudspeaker.
Here is a list of what I tested :
  • Restart in safe mode
  • Verifying android update (nothing since the beggining of january)
  • Updating all of the apps (everyday we have one so…)
  • Trying audio test in manual mode => 1 & 2 OUT, 3 works well.
  • Using the dictaphone => micro 1 works when I change codec to HE_AAC_V2
  • Uninstall useless apps
  • Disassemble parts and re-assemble => Works for 20 min.
  • I tried something in the settings (wifi call, bluetooth and others things around audio).
The fact that the dictaphone works with another codec tell me that it’s more probably a software problem, but I’m not sure.
I just contact the support to launch the guarantee procedure, but I’m freelance and I need a phone to work, so here a message :slight_smile:
What do you think?
Thanks a lot !
Just to be clear, it is the same in safe mode? And if yes did you try without SIM as well? And it happens with all Apps using those 2 mics or are we mainly talking about phone calls?
Thanks for your response :slight_smile:
In safe mode or normal mode, micro 1 & 2 don’t work, and it’s global. On telegram, whatsapp, phone calls, messenger, etc…
The only exception is with the dictaphone. With custom settings (codec HE_AAC_V2), it works, and when is default settings, it’s not.
I just tested without the sim. That’s the same :S
Have a nice day,
Are you sure that when you change the codec that still mic 1/2 is used? I would rather think its a hardware issue and the mics are on the main board. As support is really really slow at the moment, I would strongly suggest to contact them via online Chat, opening hours change, currently it should be this
https://forum.fairphone.com/t/fairphone-support-no-response-received/115916/19?u=yvmuell
When I change the codec on the dictaphone, the mic at the top works but only on this app.
I solved the problem for 2 hours this morning (all microphones has worked). The procedure was to go to the shortcut interface “micro on/off” et restart. It’s very strange honestly ahah
For the chat, I program it, thank you :slight_smile:
In my eyes its either hardware or an App. To exclude a third Party App, see if you can “fix” it again and run the phone in safe mode for a longer time.
On the FP4 there were instances were the Google App caused issues with the mic, and removing mic access for the Google App helped.
I did multiple tests yesterday and this morning. Everything go to a software problem apparently.
I restart in safe mode the FP5 and did my trick with the dictaphone (codec) => Micro works.
I decided after that to restart in normal mode and just use Telegram, Whatsapp, Browser et Phone calls. This morning, everything is fine… And the quality is good.
I think, an app, perhaps an update of an app, create a conflict with the micro. And it’s not Google app (I tried your solution but no effect sorry).
I need to diag which app cause this. But how determine this… That’s a question ahah :smiley:
I think I need to do some unit tests. An Excel with all of the app, and start the micro/start another app and see which cause this problem…
Maybe it helps to check the permission manager to see which apps have Mic access and deactivate/activate one by one
I have tested this idea on tuesday, but was random ahah.
I note, thank for yor advice :wink:
Finally, microphones 1&2 doesn’t work anymore. It’s just a total frustration ahah.
I heard me behind a interference buzz sound.
I will contact Fairphone by chat on tomorrow.
Any news?
I don’t use mics a lot but I’ve just discovered that Mic 2 (at the top) isn’t working or cannot be selected. Using the tests in the “My Fairphone” app, it’s Mic 3 [Edit: actually Mic 1] which is used for the test of “secondary microphone” …
I tried using three different recording apps, They all behave the same way : no matter which mic I select in their app “settings”, they only use Mic 1.
The hardware test using * # * # 2 8 8 6 # * # * shows no problems, all three mics correctly routed to bottom speaker. I would think that’s pretty clear indication of a software issue, presumably in the OS.
Composants was replaced by a pro. Motherboard perhaps :confused:
I used the guaranty.
Have a nice day
Thomas
