What capacity of micro-SD cards does the Fairphone 2 accept? My 160GB iPod Classic has died and am looking to replace it for music use.
Thanks!
Thanks!
Have a look here:
It should cause no problems using an SD card in the Fairphone 2 that exceeds your iPod Classic’s capacity. ![]()
The technical specs don’t mention a limit, only “MicroSD Support: SDHC, SDXC, UHS”.
This support article mentions a limit of 64 GB, but in practice that doesn’t apply, I use 128 GB myself (with LineageOS) without problems so far. Have a look in the topic @urs_lesse linked to at what other users use, only some particular cards seem to generate problems.
Also …
256 GB SanDisk in my FP2 working wihtout any problem.
Is that the Ultra A1?
I have added it to the list of compatible cards (see above the postin by @urs_lesse ) . It’s the 100MB/s version:
SanDisk ULTRA micro SDXC UHS-I 256 GB (the up to 100 MB/s speed version) (SDSQAR-256G-GN6MA
Edit:
Corrected the speed details.
I’m looking for a micro SD card that I can use to store many apps in it, for my music collection and also to record high quality videos. But obviously it is essential that it works 100% in my FP2 with Open OS, so I would appreciate the experience of other users of FP2 Open OS with similar card features.
