I want to try my hand at designing a protective cover just for me, but I found that our caliper is broken and I will not take measurements with a yardstick.
Scroll down a couple of posts in the topic above for a link to a repo of the same designs converted to .stl (which should be compatible if the .stp files aren’t, unless I’m mistaken).
Or do you want to do a cover that wraps around the existing slim cover?
In that case I guess you have to contact Fairphone, as I don’t remember having seen files to that extent.
https://www.fairphone.com/en/about/contact-us/
(In my opinion most likely “research”.)
