Hi there!
I have a FP1 but have some issue with the battery too, so I am looking for either a new FP1 battery (to keep on using my phone) or a FP2 (to upgrade my FB experience) to buy.
Thanks in advance for letting me know!
Federico (Italy)
Hi there!
Federico (Italy)
Have you seen this topic?
Thank you @BeMiGro! That’s why I’m looking for an original battery…
why not try the generic battery and if it doesn’t work then get a FP2?
Thank you Schilvy, good point!
Can someone recommend a good generic battery for my FP1 (U)?
Thank you in advance!
Federico
Well, You can use all of the batteries mentioned in the thread. My wife and me, we are using the Akku-king for more than a year now. And everything is working fine. But others here in the forum are using the vhbw or the jubatec and there are no complaints as well.
So, You are free to chose.
Great! Thanks a lot Bert!
Federico
Hi Federico,
if you’re still looking, I have 2 FP1 batteries that I used alternately from mid-2016 to late 2018 (which is when my FP1 died). If you want one or both, let me know.
Tanja
Thanks Tanja! I’m about to send you a PM.
Federico
