Looking for a FP2 Battery - Netherlands
FP2 Battery
My FairPhone 2 is not charging anymore. Already tried various charging cables, but I am quite sure it is the battery as it was getting very hot all the time. Anyone offering a FP2 battery or a complete FP2 with a well functioning battery?
Netherlands (Utrecht region)
Do you really want a used one?
You know there are still new ones to be bought from the Fairphone Shop at a low price?
By the way, a simple test you can make: Take the battery out of the phone and place it on a really flat surface. Try if you can make the battery spin (rotate) – if it spins easily, it is starting to bloat and should not be used anymore.
