Location Service (GPS) issues with FP Open OS running OpenGAPPS and Xposed
I installed FP Open OS, the OpenGAPPS pico and Xposed a couple of days ago. Everything works fine except for the Location Services. After install the error message “Unfortunately, Google Play Store has stopped.” popped up, but I read here (I think from @freibadschwimmer) that this can easily be solved by turning location off. I did and everything does work fine - except for the location services.
I also read that people compiling Open OS themselves in the early days (January ish) had the same problem and @flipreverse found a solution for this. Reading this forum I came across the Unified NLP and had a look at F-Droid. There I saw that I have the NoGAPPS already installed (concluding it comes with Open OS) and that there’s also a GAPPS Version. However, from what I read it seems that I cannot just deinstall or install those like regular apps.
Can somebody help me with this issue? Should I just install the other version, or do I need to run/implement any scripts?
Edit: Implemented the new OS name :wink:
I think that comes from GAPPS.You can see it at my Screenshots. If i want do uninstall the one in the middle, it is the Google Play Services.
But i tried the other Version (GAPPS) and (NO GAPPS) without effort.
I try to install the other Apps, listed there. At the description from µg UnifiedNlp (no GAPPS) they talk from different backends which has to be installed.
I’m actually wondering right now if microG would a better option than OpenGAPPS and opened a new post to see if other members here have already tried it and what their experience is so far.
I tried the whole microg thing without effort.
The blank store doesnt show all apps and GPS doesnt work either.
As far as i understand you need in each case a Backend App (Screenshot). And every app uses a alternate way to locate the position. But i want simply locate the phone with GPS and without any databases etc.
