Since updating LOS to LOS + microG I have a problem, that the Yalp store does not get an internet connection anymore. I have disabled all the microG services and checked my firewall. If I open Yalp it wants me to choose a fake or google account to login. I choose fake - it tries to authenticate, then the info “No network connection”.
I have also deleted all Yalp data and cache. No difference.
Thank you for the hin. I installed Yalp version 0.35 and it’s working now.
Well ok. Yalp found the updates, but downloading is failing. Will try again tomorrow.
I had the same issue.
Removing Yalp and installing from github worked for me.
I wonder if fdroid will now update Yalp, or if I need to remove and install from fdroid again…?
You’ll need to remove and update from F-Droid because APKs will have mismatching signatures (Android security model behaviour to avoid one developer impersonating another).
Same here. It worked for me after enabling ⋮ → Settings → Download to internal storage (which IMO should be the default, optionally exporting whatever APK you want to preserve in the storage).
