Lineage 18.1 - finally official
Soooooooooo…
Please note three important things:
  1. Flash the Lineage recovery: TWRP is not supported right now.
  2. You need to install new gapps at the same time as you install the new official 18.1 build!
  3. You need to wipe your data: meaning that you will loose your previous data on the phone. Unfortunately this is necessary as we cannot decrypt the phone or use the lock passphrase in 18.1 anymore. Google has deprecated the old keystore mechanisms in AOSP and lineage does not have a hack for this. So please backup photos and other stuff.
Rgds,
Chris
Will it be found here? (Not there yet right now.)
https://download.lineageos.org/FP2
Yes - but lineage only builds once a week nowadays - so still a bit of patience required.
Chris
Does this mean encryption is gone as a feature for now, or does it just mean LineageOS 18.1 can then encrypt with a new mechanism?
Does this also apply if the data partition is not encrypted?
If you have a screen lock. You can try to remove screen lock prior upgrading.
Chris
It means that you can encrypt again after upgrading with different mechanism/way.
Chris
Can we upgrade from Unofficial 18.1 ? :slight_smile:
If the answer is “not sure” I’ll be happy to test myself :smiley:
Read this please: Signing Builds | LineageOS Wiki
Chris
Actually I didn’t fresh install 18.1 unofficial (it was causing my banking app to refuse to launch), but I installed 17.1 official then flashed 18.1 unofficial.
So -in my opinion- I don’t need to migrate the keys, just flashing 18.1 official on it.
Anyway we’ll see as soon as the new build is available, hopefully this Friday :wink:
I’ll do a TWRP backup first then test all I have in mind :smiley:
As a happy user of LOS 17.1 for quite a while already I can only send a big thanks to all people who make this possible. Now that upgrading to 18.1 comes into reach for me I wonder if someone who has already upgraded could briefly summarize what are the biggest differences between those two? In the previous LOS 18.1 thread I found that pretty much all components should be working and a vague statement about battery life. Can anyone confirm this?
SIGH
Please don’t recommend not-recommended procedure to the usergroup just because it works for you. Lineage people might refuse bug reports or other valid concerns when documented procedure is not followed.
Chris
Great news and thanks for your hard work :). Can you hint some general information on improvements over the last official release?
You can start here
The file is up:
update successful, without data loss :smiley:
(I just flashed the zip with TWRP 3.2.1-0)
Thank you to all contributors!
@oli.sax so you ignored all “no goes” by using TWRP and just flashing official over unofficial 18.1 Version without any issues? Thats interesting, however I assume everyone doing this should know, that this can cause issues, correct?
Yes - why do I even write instructions.
I removed the lock screen of my unencrypted FP2, created a backup with TWRP and installed 18.1 without wiping the data partition. The phone booted to the PIN screen but would end up in a boot loop after I entered the PIN of my SIM card.
The phone booted fine after I wiped the data partition. When I flashed TWRP again and restored the data partition from the backup I was back in the boot loop.
I restored 17.1 from the backup for now but I will install 18.1. again once I have a plan to migrate any app data I don’t want to lose.
Just thought I’d share my experience to maybe save someone else some time. Thumbs up for Lineage 18.1 for FP2! :+1:
I switched to 18.1 and followed the instructions: formatted/wiped the data partition with the LOS recovery. Worked out very well, +1!
Two things I have noticed so far:
  • The LED does not show any light when the battery is fully charged. (In 17.1 the LED stayed green.) The battery icon in the top bar shows that the battery is being charged.
  • In common phone conversations performed with the phone app, some people say that they do not hear my voice very clearly. Can the microphone input be adjusted anywhere?
I would like to thank everyone involved for the hard work to make this happen, great job, thank you so much!
