Hi @Allan1. I am having the same problem with mobile data not reconnecting after turning it off and on again. It only works again after rebooting. I’m on giffgaff in the UK and I checked the APN settings. The default settings included are not the same as the settings on giffgaff’s website, so I changed them, but no improvement. Anyone else having the same issue?
EDIT: Updated to 08/04/2020 build and mobile data seems to be working again…
does the alarm clock work properly for you? With the defined sounds and increasing volume? Otherwise I have to build a bug report, because some more does not work for me than under Android 9.
hey @gapintheclouds. cool, that the update fixed the issue on your phone. Sadly it didn’t work with my one. I guess I will try a few more nightly updates and if that doesn’t work wipe my phone completely and install lineageos 17.1 from the scratch. I just don’t have any better idea
Then used SatStat to verify that the location is available (it took several minutes to get the location).
Immediately afterwards I enabled Dark theme in Settings > Display, then tapped Dark theme and set Schedule to none, then back to “Turns on from sunset to sunrise”
After a few seconds Dark theme was automatically turned off which was the expected result during daylight.
I waited then until sunset: Dark theme was turned on automatically.
So it works for me even with “Device only”. But it is easier to get a location in battery saving or high accuracy mode.
Remarks
.) removed Yalp for good; Aurora works nicely
.) at least in my case no reboot possible as long as device is connected via USB to PC.
Neither buttons, nor e.g. ‘sudo fastboot devices’ – hangs with ‘Fairphone’ splash screen.
No problem tough rebooting when disconnected.
The text says that google apps are optional. That is in the sense that if you haven’t used gapps previously you’re still not forced to use them.
But if you had gapps on the old version, you must also update them in the same step. The instructions could be a little more clear on that.
Is there also a replacement for GravityBox? I’m still missing some functionality:
– “close all apps” in the App overview
– Editing the no. of functions in the status bar. Before I had 7, now only 6…
“close all apps” is still there in the app overview. You have to scroll to the very left. Which makes the function somewhat tedious to use when there are a lot of open apps.
