Thanks
If I want to update from FP Open - just delete and flash or do I have to install recovery first?
I donāt think that the recovery of the latest FPOOS is able to flash the system. Youāll need to flash TRWP or LOS recovery first.
Just to confirm that the updater indeed was fixed in 20200404: update to 20200405 went smoothly (I have TWRP 3.2.3).
Iāll try these and report back, which one I like more ;). But I still think that is makes no sense to discontinue a working calender app integrated in the base OSā¦
Of course that makes sense. Who does the heavy lifting to give you AOSP, and who wants you to better not use it as it is but go for their set of āimprovedā Apps instead
Does anybody know hot to get the automatic daylight depending switch from light to dark theme to work?
I found this article on XDA, which says, that the automatic switch is deactivated on Android 10 and it recommends a small app for that feature.
So is it the same an LOS 17.1?
I understand the settings that way, that a daytime depending switch is possible.
Thanks for your reply
Yes, thats what i have done but the theme didnāt switch at the sunset. Then i switched it manually on and it showed the message, that it will turned off at sunrise.
Naturally I turned on the schedule.
So for you it works?
I waited until 08:30AM but nothing happend and switched it manuallay again.
I had a similar situation with LOS16.
The switch between themes wasnāt at the correct time until I used GPS and the phone got the correct GEO dates of the phone to calculate the sunrise/sunset. From this point on the theme switch was correct.
But yesterday I already used the gps and it seems that it didnāt take any effect.
I dont want to be missunderstood. If its a bug, iām totally fine with it and donāt want to appear unpatient or so. I can switch it manuallay until it works.
But if its a user mistake of me and it works in general, it would be nice to know
Not sure if it applies here but Iām a big user of the SMS app and noticed some problems:
- The quick reply option in the status bar is now opening the app instead of allowing a reply to be typed directly in the status bar control
- In that case (app opened from the āReplyā option in the status bar), the SMS still shows as āunreadā in the conversations list
A missing feature: no quick app buttons on the lock screen bottom corners.
Also, the notification sound is heard if any notification in the list has a sound attached to it, as if the whole list is āreplayedā whenever a new notification is added, even a silent one.
Example: I receive an SMS - notification sound is heard. I receive an email, for which notifications are silent (i.e. only displayed but no sound or vibration) - the SMS notification sound is played again.
Not sure if itās linked to the FP2 or Lineage in general, but I thought I might share it, just in caseā¦
Turning dark mode on / off at sunset / sunrise works for me with Lineage 17.1 and UnifiedNLP (location is set to battery saving mode). Are you sure there was a location available to calculate the sunrise / sunset times?
Alright.
Thank you.
I switched it again manually now and reconfigured the settings with GPS only (without WiFi & Mobile Network) and tried to controll it.
And the UI accessed the GPS as you can see here:
My installation worked fine, but mobile data is not working. I switched my firewall off, but still no difference.
Any ideas what I can try?
You should check APN settings. My one were wrong, too.
Chris
My installation (new install, after use LOS16) was very good. Only forgot to backup Whatsapp⦠(I donāt use Google anymore).
Now my rotation (screen), pedometer en acceleration sensors are working now on.
I had also my mobile data not working, but after a reboot, it came back.
For the next time, a better manual to upgrade should be fine.
Happy user of Lineage OS 17.1, good work developers!
Just wanted to tell everybody that my update went smoothly!
I am very happy with Lineage 17.1 now. Thank you so much @chrmhoffmann!
I went to settings ā mobile ā APN and used the āreset to standardā option. This did it.
@chrmhoffmann: thanks for your work with LOS
The question is: was the access successful? Did it get a location?
LineageOS 17.1 is running well here and it is awesome to have a phone that started with Android 5 and is now running Android 10 ![]()
Just wanted to add my voice to the list of thanks to everyone who helped bring 17.1 to the FP2! Great job, people! Thank you!
One question I do have: Has anyone been able to successfully install the FDroid privileged extension on 17.1? Iām asking because I have tried several times - both with TWRP and with the LOS recovery - to flash it and it just doesnāt seem to want to stick⦠adb sideload tells me that it installed OK, but then after a reboot it is nowhere to be foundā¦
So, does anyone know what Iām doing wrong?
