I have a similar issue sometimes when I drive my car into the garage (where I lose my mobile carrier), and go upstairs into my flat afterwards (with WLAN Internet): The FP2 connects to WLAN, but I cannot access the Internet anymore unless I reboot the phone.
Would that fix help in this scenario, too? If yes, I would gladly test the fix. Thanks in advance.
After some days testing I can confirm, switching to mobile data and turning it off and on (or using the flight mode) does not have any influence anymore. I would say the fix works.
I did the test: I drove my car into the garage, then I went into my flat where the phone connected to WLAN, and ⌠Internet still works! Will do the same again tomorrowâŚ
Is it safe to apply OTA updates as long as the fix is not rolled out, yet, or would they overwrite the patch which I manually flashed before?
This is a binary blob from a different device. Not compiled from source. For unknown reason it works better. Not great solution but better than the issue.
I tried to do so but could not get the adb root done. I use magisk which seems to cause this problem. Is there a way to do this using adb shell? In here I could get the superuser rights but didnât know the necessary commands.
Yep, developer options are activated. But I canât find an option to activate root debugging which I think comes from Magisk. There I actually gave superuser rights to ADB and Apps but still adb root does not work.
Hints are welcome
Applied your patch on Tuesday. Since then I havenât encountered any issues! It seems to work flawlessly!
(Before, my phone wouldnât connect to the internet after either losing my mobile carrier, deactivating flight mode or switching between WiFi and mobile data.)
Huge THANKS!
