With the build from May 28th, I had no problems with the mobile data, but will update to build 26.06. today and recheck. I will also install the modem.zip.
Iâm on 20200626; more frequently âyesâ than âsometimesâ
Where can i find this settings?
Edit: I got it from the current build info (lineage-17.1-20200703-nightly-FP2).
I could imagine that this is only available if both devices (phone and speaker) support it. In FPOS it isnât available and therefore the modem files I guess donât have that, either. There was a thread about aptx on the FP2 earlier and someone got it to work with an earlier Lineage version:
I have the latest nightly 20200703 and the latest modem driver 19.11.2 on FP2. Since when I upgraded to lineage OS 17.1, I have a problem with very low volume during a call. Indeed, I have to use speaker in order to listen the other side. Is there any way to fix this?
Thank you
Thank you very much for your answer.
I tried to find a location in the apartment and after 10 minutes still nothing happened. I live in Vienna, so GPS tracking should be successful rather quickly Wonât MicroG install Google services again? Actually I would like to avoid that.
Finding no location with only GPS indoor, seem quite normal to me, at least with the FP2, I have LOS 16.0 installed with GApps and its the same. Once I turn high precision the FP finds lication within secondsâŚinstalling microG does not mean installing Google tools, but replacing some âimporantâ Google Features e.g.for locationâŚit somehow fakes ânormal Android feelingâ without having Google installedâŚ
Iâm on 20200703 and I recognize three issues:
the time set in Settings > Security > Screen lock > Lock after screen timeout doesnât have any effect (it was mentioned here before for a previous update)
the main camera is not available
the torch is not available
Can someone confirm?
Thank you. Itâs always amazing what you donât know.
Iâll give it a shot.
Confirm same her, on top of the no mobile data after flight mode/wlanâŚ
Didnât check the screen lock timeout but I cannot confirm the camera and torch issue. Is this with the 12MP camera? I have the old camera module and I would assume that if the camera is not recognized the torch doesnât work either. So issue 2 and 3 are related.
In the meantime I had to investigate the mobile data issue a little bit: I donât need the flight mode to not have mobile data available but it is sufficient to just turn off mobile data and turn it on again, then this doesnât work sometimes. âSometimesâ often means after a restart while after shutting down the phone and booting it up again toggling the mobile data usually works. I could imagine that re-installing the modem files (or anything else) via TWRP has a similar effect on the phoneâs state as a fresh start from having been switched off and therefore this has worked for some of us.
Can confirm
- screen lock
Canât confirm
- main camera
- torch
Both are working, 12 MP camera installed.
Can you actually confirm all three issues? Martin_Anderseck and StephanK canât confirm the camera and torch issue.
I canât figure out whether this is a software or hardware error in my FP2.
When I search for torch in the settings and touch on the result, nothing happens. And the torch tile is greyed.
I have installed the new camera module. Not with Open Camera nor with the stock camera app I get an error message. In both there even is no way displayed to toggle between the selfie and the main camera, as if only the selfie camera exists for the software.
So I thought that this should be a software fault.
But when torch and camera are related, as Martin_Anderseck said, this could be a hardware error.
I am confused.
Iâm on 20200619, and I confirm that if I switch mobile data once on it works, but if I switch it off and on again it doesnât anymore, until I restart the phone. Flight mode on off doesnât change anything.
What I donât understand is that Iâm having this issue now, started a few days ago, although I havenât updated Lineage for three weeks.
Also, I received a notification of a bugreport a few days ago (perhaps related with the problem), what should I do with it?
I reported a similar issue here: https://gitlab.com/LineageOS/issues/android/-/issues/1891
confirm the mobile data issue - this I can replicate and occurs every time as described - switch flight mode/wlan
torch and camera does occur, but I can not replicate it or nail it down to what is the trigger , it is not a hardware problem, since a restart resolves it
(it is the newer 12MP camera module btw)
Question: do I need to reflash the latest modem.zip after every LOS Update again?
No. The modem files are in separate partitions a LineageOS update doesnât touch.
Thank you for your answer. I just restarted my phone, but the torch and camera issue still occur. So in my case I am not sure that this is a software fault.
When it occurs to you, is there also the torch tile greyed and in the camera app(s) is also nothing offered to toggle between the cameras?
torch greyed out
camera app crashes / stucks or in the best case offers some error message
does not matter which app default or open camera
Strange. The stock camera app and Open Camera never display any error and they work fine also, but both do not offer anything to toggle between the cameras, as only the selfie camera was installed. They even do not seem to miss the main camera.
