Just download the file from the lineageos website. It is some kind of bug that you don’t see it in the updater.
And then flash it like an upgrade?
4 posts were split to a new topic: What to do with long topics about many issues
I report that in the last version (updated 29 may 2020) I cannot connect the mobilephone via USB to the computer…
Thanks!
The phone did not let me sleep due to the randomly notification sound, even though the phone is muted, which seems to be caused by the stock clock app.
I updated to 20200601, what I had to do via adb sideload due to an updater issue. (Hope, it is fixed in this version.) But unfortunately the clock issue isn’t fixed yet. So my FP2 keeps on playing its notification sound randomly.
Hey there,
I am not able to flash / sideload my modem.zip.
I countinouosly run into error no. 7, it (roughly) says: This file is for FP2. Your device is .
I tried it several times using different lineage builds (currently on 20200603). Also updating to the older modem-19.05.2 didn’t work.
Does anybody have an idea on what to do / try?
Thanks in advance!
Which recovery do you use to install the modem.zip?
If TWRP, which version?
I use TWRP 3.2.3-20190509.
I would first try a different TWRP, you can just boot one with fastboot, see #twrpwoflashing.
Thanks a ton! It did work!
The mobile data problem is gone for me only when using 20200429. I tried flashing newer versions but they all have the problem so I keep reflashing 20200429…
I can confirm. I have set timeout to 10 minutes.
It seems it’s corrected in 20200605.
I can confirm this…
Sadly I cannot confirm it. I have 20200605 on my phone now but the mobile data bug remains. I can solve it by deleting the APNs, rebooting and creating new APNs. After doing that everything works fine as long as I don’t reboot. Then I sometimes have to repeat this procedure.
The very good news is, that on my phone both AFWall+ and Adaway work nicely now.
Me too. I have 20200605 on my phone now but the mobile data bug remains
For my phone it’s the first time with Lineage, I installed 20200605, had the mobile data issue first but flashed the latest modem files again and since then it’s working fine. With that kind of issues I was hesitant to install 17.1 first but now everything went so extremely smooth, that’s really awesome. Thanks for that!
On a sidenote: Battery life especially in standby seems to be improved compared to FPOS, however my Android 7 had a history starting from the original FPOS with Android 5…
I have 20200605 installed now and the mobile data bug returned somewhen between my last post and now, apparently. Re-flashing the modem files did not help this time…
I have the interesting feature, that switching from WiFi to mobile data works, but there is always an “x” at the bottom, In WiFi it says, “No internet”, but I can surf fine.
