LINE, Signal, Threema & co in FPU1?
Hi people
I’m trying to install “LINE” in my oldschool FPU1. Even if a choose old versions it appers alwayss the message “parsing error”. The only one messenger I could install was Telegram. Do you know a solution for this problem???
SAludos!
this is just a guess but as you wrote you installed an old version of the app and there is a parsing error it sounds like the old version isn’t able to decode messages sent by newer versions of the app anymore. In this case probably there’s not much you could do.
Apart from Telegram Signal and Threema work fine on my FP1 running Android 4.4.4 btw.
For those wanting to follow and upgrade to the unofficial 4.4.4.:
