Keyboard lag problems (fails to load or sticks on screen too long)
My on-screen keyboard isn’t responding properly to my requests to type. The keyboard often takes a long time to pop up when I click into a text box (or it pops up finally only after I close and reopen an app/browser and try again). It also often lingers on the screen long after I’ve closed a text box or app (locking and unlocking my phone seems to make it go away).
It’s becoming increasingly frustrating, and I believe it started happening 2 updates ago. The most recent update did not fix it (I hoped it would!).
Anyone else experienced this and found a solution? Thank you.
Hi fancemma,
I haven’t experienced that problem yet. But it might be worth a try to delete the cache of your keyboard app (GBoard ist the standard app if you are using FPOS).
Settings → Apps → GBoard properties
Greets Robert
Thanks Robert
Tried clearing the cache. Problem still there. Hmmmm….
Emma
I’m having something similar. When I scroll. If I lock and unlock it’s back to normal but frustrating it always freezes
Will let you know if I find a fix! Have you tried anything?
I also find that my phone can now be slow to load more generally.
I factory reset my phone last night.
The keyboard problem persists :pensive_face:
