Wonderful: my bank wants to implement 2FA for all transactions. I have to install SecureGo on my mobile FP2.
I managed to download the app without google getting access to my mobile (hopefully).
Finally I found an apk downloader site.
NOW I cannot start the app because it has found a jailbreak or Root on my mobile.
But root is disabled.
…you are trying to reduce the impact Google has on your phone. Did you by any chance remove some of the Google Apps from your device in that process, like for example Google Play and the corresponding Google Play Services?
Or are you running a custom ROM without GApps installed at all?
Both of those case will prevent your banking app from working because it’s checking for the existence of the Google Play Services and it possibly checks if your phone passes SafetyNet as well.
Banking Apps are known for their supposedly strict security requirements, and the messages about checks for those requirements failing tend to not say what’s wrong exactly.
That would be my guess as well, @andreas1 please provide detail on which OS you use and how you avoid Google.
Else it could also be a detection of an unlocked bootloader. The bootloader of the Fairphone 2 comes unlocked and can’t be locked.
I have no GApps at all on my fairphone. And wanted to evade it right away.
FP Open 22.02.0-rel.0 is my OS.
I asked my bank again today. And I have this TAN generator device which never worked properly via my Ubuntu PC. When I get this started I can forget about this google app… hopefully this works.
All Raiffeisen banks have implemented 2FA with SecureGo now. My bank calls itself Ethikbank…
For me it’s an insolence forcing people to use Google after all these discussions about tracking of GAFAM.
My company uses MS which sends me an SMS on my mobile in order to log in on the company laptop when I am doing homeoffice.
By the way: how do I „deactivate“ the google apps as Yvonne suggested ?
When you use Fairphone Open, no Google apps are pre-installed.
A note for the future: If you still need to use some apps that are only available in the Google Play Store, you can use the Aurora Store, which you can find on F-Droid.
If you want to use a smartphone for banking. That’s an if.
You can choose not to and use a simple TAN generator for online banking with a computer. Sounds like you have a cardreader for computer use? Even that wouldn’t be necessary for chipTAN or photoTAN.
(Except with banks not offering sensible options because they don’t want to have informed customers … wait a minute … over time we’ll be doomed .)
don’t forget to tell your bank that you’re a dissatisfied customer because of this. If enough people complain (i.e., announce they’re informed, according to @AnotherElk), maybe they change their policy. If they don’t get complaints, they never will.
When I complained with GLS Bank, I ended up with a technical person who understood the complaint and offered another route (no smartphone banking, though).
