Jabra Elite 8 and FP6
Hiya,
I’ve just got my FP6 (normal) and my jabra Elite 8s aren’t working with it. They paired without an issue but when I try and play media (tried audible, youtube, yt music, podcast app) but this just causes the headphones to unpair and repair without anything coming through the earbuds. I’ve tried looking at various permissions but nothing seems to be causing it… any advice?
Update: tried it with other earbuds and they work fine
Did you try resetting the Jabras? Don’t know how to, but just search for it.
Make sure you have the latest Firmware via Jabra’s App.
I’ve reset the headphones and they have the latest firmware but same result.
Might be a codec problem.
You might compare the specs of the two devices.
For FP6, the official specs say
  • The supported formats include: SBC, AAC, aptX, aptX HD,aptX adaptive
We did have many different issues with Jabra and different Windows Laptops and Jabra drivers to install and different headset models having different issues.
We finally went for simple no name ones. They just workes out of the box :slight_smile:
I managed to get them working, following the advice from Jabra - which is broadly similar to advice given but here’s the full techniii followed:
Thank you for contacting Jabra Support. To address the challenge you have described with your Jabra Elite 8 Active, please follow these steps:
Reset your earbuds:
Go to the Bluetooth menu on your mobile device and unpair your earbuds by selecting Unpair/Forget this Device (or similar).
Turn off the Bluetooth setting on your mobile device.
Turn your mobile device off and then on again.
Place both earbuds in the charging case and leave the lid open. Ensure your earbuds are sufficiently charged.
Press and hold (10 seconds) the Left and Right buttons on the earbuds simultaneously until the LED on the inside of the charging case flashes pink.
Close the lid of the charging case (5 seconds) to complete the reset.
Note: You cannot reset only one of the earbuds.
Turn on the Bluetooth setting on your mobile device.
Remove the earbuds from the case and re-pair them to your mobile device by selecting the Jabra Elite 8 Active from the list of available devices in the Bluetooth menu.
Update or re-install the firmware:
You will need to use the Jabra Sound+ app. You can download it for free here:
Jabra Sound+ - Android
Jabra Sound+ - iOS
Make sure your earbuds are paired with your mobile device and have at least 50% battery.
Open Jabra Sound+ and make sure the earbuds are detected (they will be displayed by the Jabra device name as yellow circles with an L and R and may take a few minutes to appear).
From the main headset tab, click on the Settings icon in the top right corner.
If there is a new firmware version available, select Firmware update available.
If there is no new firmware version available, select Personalize your headset, then Voice guidance language. Re-select the current language of the earbuds.
Tap Update Now and follow the onscreen instructions to complete the update.
NOTE: Do not open the charging case until at least 10 seconds after it has stopped flashing pink. If the LED does not stop flashing after 15 minutes, open the lid of the charging case and close it again.
If an error occurs during the firmware update, the LED on the charging case will flash red. To restart the firmware update, make sure the charging case is connected to a power supply, remove the earbuds from the charging case and then place the earbuds back in the charging case and close the lid.
There’s also a button on the Bluetooth/connection menu called “LE Audio”. My headphones stopped working again today for no obvious reason and after a bit of faffing, turning that option off for them working again.
