“FP1_KolaNut_v1_8_5_OTA” via recovery mode?
“Installation aborted” again!
Diagnosis from the distance is difficult… You might have to do a Hard Reset.
Hi Christoph,
I’ve had this problem for months and months. I don’t have a solution for you but I can tell you that from my experience, hard reset doesn’t work. I’ve been told all sorts by moderators in the forum and none of it has worked.
I like my Fairphone, but I’ve given up.
@Darren_Coyle If you allready have a unified storage, an sd-card and performed a hard reset then I believe the forum might no longer be the right place for you to find a solution. Please contact support. Don’t give up.
I did the “hard reset” as Stefan mentioned yesterday and finally it seems that there is no insufficient storage error anymore.
I was able to update all the google stuff again.
Thank you Stefan, i hope that this was the solution for this problem and won’t occur again.
Chris
