Installing /e/OS on Fairphone 6
Hi everyone,
i recently bought my Fairphone 6 and tried to install e/OS. However it isn´lt working.
My background: first phone I´m trying to flash, I was told the flash-proces should be easy and unproblematic with the easy-installer. [Given that this is my first time trying flashing, I took a lot of advice for troubleshooting from a language model :expressionless: ]
However, regardless of what i tried, i couldnt finsish the flashing process. Furthest point was, when my computer startet my phone into the boot-menu, however, then being unable to detect device, see screenshot.
So i talked to the language model for troubleshooting, it said that the flash-image for the FP6 hasn´t been published yet, even though the e/OS installer is listed here: Smartphone Selector .
So I was wondering, whether any of you sucsessfully managed to flash their FP6, or if the LLM might be right.
Thankful for any advice:)
S
Which system is installed on your PC.
Windows 11,however I also tried with Windows 10 and Ubuntu via a life-booting-stick
ok for windows check this reg driver and update the bootloader driver as described
I imported a Fairphone 6, with the standard android operating system with the plans to put e/os on the phone myself. I’d never done this before either.
I have now successfully flashed the Murena e/os onto my FP6, which is working without issue.
There was a lot of troubleshooting I had to go through until it worked.
Firstly, I believe I read somewhere that the web installer is not very successful with flashing e/os onto a FP6. I got as far as 22/24 steps, using the online installer (some writing error message stopped process) - which left my phone looping in unlocked fastboot mode. It was after this, I think I read to not use the web installer for FP6.
I think the manual method is recommended for the FP6. I was successful in flashing my unlocked fastboot looping FP6 using the manual method. You’ll mainly be working with command prompts in a terminal window. See instructions below:
A few things I found that helped along the way:
- Ensure the cable to connect your phone to your computer is a data transfer cable, not just a charging cable. I got a few off of amazon, try different cables and different USB ports.
- I was successful using a USB booted version of Linux Mint, on a windows laptop (I seemed to get more errors in Windows 11). I was using a 32GB usb drive, and kept running out of space (installation files, and Platform Tools need to be downloaded into linux) - so you might want to uses a USB with more that 32 GB of space as your linux boot USB.
- Do a search on every error message you get (I copy and pasted the error wording). I also used LLM feedback re the errors I received, and it usually gave me a very detailed way to resolve that particular error. Internet searches with specific errors were also helpful.
- If you’ve not done the “developer mode”–> OEM unlocking and USB Debugging (in your phone settings) make sure you do this, and verify it’s done. This is described in the link above.
- Per the instuction page above, if you get to the point of trying to write the e/os to you phone, the linux command “ chmod +x flash_FP6_factory.sh && ./flash_FP6_factory.sh “, will likely be your final step to being successful. This step initially gave me many errors, but LLM search of the exact error wording usually gave me a way forward.
- You may need to install an android / google usb driver, once you are in Linux.
- You’ll have two items to download: sdk platform tools, and installtion file (link to installation files in link below, or from installation instruction page). Ensure you have the same version of Android on phone (likely Android 15 if recent purchase), as you do for installtion files. I used the 3.2 version of the “offical” Android 15 builds:
- I ran into issues related to permissions (of various files). If you are using Linux, right click on the “platform tools” folder, go to properties then the permissions tab, and give all users “read and write” access. I think I also did this for the “installation files folder” you will download as well. I ‘think’ this resolved some of my permission errors.
- Ensure you “set a path” to your platform tools folder. I flashed my phone from a Terminal window opened from within the installation files folder - so linux will need to know where to find the adb and fastboot files (within your platform tools folder).
- Are you still able to use your phone with the stock android software? Or are you stuck in some sort of software looping? If you are stuck in a loop of any sort, the hold “Power button + Volume up, or down” - will be your friend to access either bootloader mode or recovery mode.
It took me well over a week, and a lot of long (frustrating) hours to get this to work …. so don’t give up! :smiling_face_with_sunglasses:
please have a look there…
Thanks for your support, guys <3
I managed to install the corret drivers and unlock the bootloader; however i ran into a new problem:
I cannot execute the command to actually flash my phone. MS Powershell doesn´t recognize the command “chmod +x flash_FP6_factory.sh && ./flash_FP6_factory.sh” from the official website, not does the command “bin-msys\bash.exe flash_FP6_factory.sh” work.
A LLM mentioned, that my downloaded files are missing a bash.exe, fastboot.exe and adb.exe files, however, i just downloaded the FP6 img files several times & unpacked with 7zip and it yielded the exact same results every time.
Do I need to download git-bash, is there something wrng with my commands or are my files actually missing .exe files?
And do the adb and fastboot commands need to be defined globaly, because I did the unlocking by opening the terminal in the tool-ordner and now i switched to the imf. file ordner.
Again, many thanks in advance you guys :>
yes, it is needed when you are limited to Windows.
