đŸ‡«đŸ‡· 🇬🇧 Installation /e/ sur fairphone 3
Bonjour,
J’espĂšre que mon sujet n’a pas Ă©tĂ© traitĂ© ailleurs, j’ai cherchĂ© sans succĂšs :
J’essaie d’installer /e/ sur mon fairphone, mais je bloque toujours au mĂȘme endroit aprĂšs plusieurs tentatives :
Je suis sur mac, j’ai bien activĂ© fastboot et adb sur mon ordinateur, j’ai dĂ©vĂ©rouillĂ© le bootloader et activĂ© le dĂ©bogage USB de mon appareil.
Je bloque juste Ă  l’installation de /e/ sur le tĂ©lĂ©phone : j’ai tĂ©lĂ©chargĂ© le zip sur mon mac (IMG-e-0.17-q-20210621120947-stable-FP3), mais la commande
unzip IMG-e-0.17-q-20210621120947-stable-FP3
ne fonctionne pas. Je peux certes dézipper manuellement, mais aprÚs aucune commande ne fonctionne, à partir de celle-ci
fastboot flash system_a system.img -S 522239K
, rien ne marche. Je ne suis pas trĂšs Ă  l’aise avec l’utilisation du terminal, merci de vos conseils pour rĂ©soudre ces difficultĂ©s !
Bien cordialement,
I hope that my subject has not been treated elsewhere, I have searched without success:
I try to install /e/ on my fairphone, but I always get stuck in the same place after several attempts:
I’m on mac, I did enable fastboot and adb on my computer, I unlocked the bootloader and enabled USB debugging on my device.
I just get stuck installing /e/ on the phone: I downloaded the zip on my mac (IMG-e-0.17-q-20210621120947-stable-FP3), but the command
does not work. I can certainly unzip manually, but then no command works, from this one
nothing works. I am not very comfortable with using the terminal, thank you for your advice to solve these difficulties!
Sincerely,
Welcome to the forum. It is over a year since I carried out this procedure upon my Mac, but no reason to assume that OSX BigSur has introduced complications.
Is IMG-e-0.17-q-20210621120947-stable-FP3.zip currently residing in “Downloads”? You can use default “Archive Utility” to decompress to get IMG-e-0.17-q-20210621120947-stable-FP3, which you have already done to get the eight .img
If I were you as my “Downloads” folder is cluttered, create a new folder on Desktop (ctrl key + mouse click) and name it FP3 or whatever. Drag IMG-e-0.17-q-20210621120947-stable-FP3 from “Downloads” to your newly created folder.
Open Terminal upon Mac then type cd / and drag newly created folder with mouse into terminal window, it then shows path to folder so in my case:
iMac-2:~ adrian$ cd //Users/adrian/Desktop/MobilePhones/FP3eOS
iMac-2:FP3eOS adrian$
Can’t remember whether you should be “sudo” with # instead of $ at the moment.
I am guessing that you didn’t point to IMG-e-0.17-q-20210621120947-stable-FP3 in “Terminal”, but forgive me if assumption is incorrect, Presumably fastboot and adb were installed via “Homebrew” upon your Mac?
Thanks for the quick answer. Yes I installed adb and fasboot via homebrew, and the fastboot and adb devices commands point to my FP3. But it’s the next step that doesn’t work
I understood that I had to point in the terminal to the folder that contains my unzipped file.
Then, I put my phone in fastboot mode, I make the command lines but it blocks again from the second fastboot flash system_a system.img -S 522239K
This is what my terminal displays.
If you have an idea of what can block
The terminal says it can’t find the file system.img.
If you are sure the file is in the folder you are operating in with the terminal, try ./system.img instead of system.img, this should force the terminal to get the file from the current folder.
Parfait ça a marché ! Merci beaucoup pour la réactivité des réponses !
@PhilippeLeBel
Glad that issue now sorted for you and for the record “sudo” is not needed by the way:
iMac:~ adrian$ cd //Users/adrian/Desktop/MobilePhones/FP3\ eOS/IMG-e-0.13-q-2020120789006-dev-FP3
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ adb reboot bootloader
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot -w
Erasing ‘userdata’ OKAY [ 0.861s]
mke2fs 1.45.4 (23-Sep-2019)
Creating filesystem with 12777209 4k blocks and 3194880 inodes
Filesystem UUID: 0580f62a-2c9f-4e4f-abf0-e59f05e7b23d
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information: done
Sending ‘userdata’ (4661 KB) OKAY [ 0.130s]
Writing ‘userdata’ OKAY [ 0.058s]
Finished. Total time: 1.316s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash system_a system.img -S 522239K
Sending sparse ‘system_a’ 1/4 (515836 KB) OKAY [ 13.303s]
Writing ‘system_a’ OKAY [ 2.376s]
Sending sparse ‘system_a’ 2/4 (514704 KB) OKAY [ 13.416s]
Writing ‘system_a’ OKAY [ 2.363s]
Sending sparse ‘system_a’ 3/4 (515456 KB) OKAY [ 13.749s]
Writing ‘system_a’ OKAY [ 2.352s]
Sending sparse ‘system_a’ 4/4 (457728 KB) OKAY [ 11.844s]
Writing ‘system_a’ OKAY [ 2.104s]
Finished. Total time: 61.615s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash boot_a boot.img
Sending ‘boot_a’ (65536 KB) OKAY [ 1.757s]
Writing ‘boot_a’ OKAY [ 0.319s]
Finished. Total time: 2.124s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash vendor_a vendor.img -S 522239K
Sending ‘vendor_a’ (430500 KB) OKAY [ 11.355s]
Writing ‘vendor_a’ OKAY [ 1.961s]
Finished. Total time: 13.409s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash dtbo_a dtbo.img
Sending ‘dtbo_a’ (8192 KB) OKAY [ 0.231s]
Writing ‘dtbo_a’ OKAY [ 0.068s]
Finished. Total time: 0.340s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash vbmeta_a vbmeta.img
Sending ‘vbmeta_a’ (4 KB) OKAY [ 0.040s]
Writing ‘vbmeta_a’ OKAY [ 0.021s]
Finished. Total time: 0.108s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash system_b system.img -S 522239K
Sending sparse ‘system_b’ 1/4 (515836 KB) OKAY [ 11.163s]
Writing ‘system_b’ OKAY [ 2.363s]
Sending sparse ‘system_b’ 2/4 (514704 KB) OKAY [ 11.138s]
Writing ‘system_b’ OKAY [ 2.358s]
Sending sparse ‘system_b’ 3/4 (515456 KB) OKAY [ 11.373s]
Writing ‘system_b’ OKAY [ 2.356s]
Sending sparse ‘system_b’ 4/4 (457728 KB) OKAY [ 9.950s]
Writing ‘system_b’ OKAY [ 2.106s]
Finished. Total time: 52.838s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash boot_b boot.img
Sending ‘boot_b’ (65536 KB) OKAY [ 1.457s]
Writing ‘boot_b’ OKAY [ 0.320s]
Finished. Total time: 1.824s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash vendor_b vendor.img -S 522239K
Sending ‘vendor_b’ (430500 KB) OKAY [ 9.375s]
Writing ‘vendor_b’ OKAY [ 1.978s]
Finished. Total time: 11.374s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash dtbo_b dtbo.img
Sending ‘dtbo_b’ (8192 KB) OKAY [ 0.211s]
Writing ‘dtbo_b’ OKAY [ 0.061s]
Finished. Total time: 0.317s
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot flash vbmeta_b vbmeta.img
Sending ‘vbmeta_b’ (4 KB) OKAY [ 0.040s]
Writing ‘vbmeta_b’ OKAY [ 0.021s]
iMac:IMG-e-0.13-q-2020120789006-dev-FP3 adrian$ fastboot oem lock
OKAY [ 0.076s]
Finished. Total time: 0.076s
Bonjour,
Je tente Ă©galement d’installer /e/ sur mon fairphone, cependant je ne peux obtenir mon code de dĂ©verouillage sur la plateforme : Bootloader Unlocking Code for Fairphone 3 - Fairphone
En effet, en renseignant les bons numĂ©ros IMEI & de sĂ©rie, j’obtiens un message d’erreur me disant que l’un ou l’autre sont faux, or ce n’est pas le cas
Avez-vous dĂ©jĂ  Ă©tĂ© confrontĂ© Ă  ce cas ? Comment puis-je malgrĂ© tout obtenir ce code pour procĂ©der Ă  l’installation /e/ ?
Merci d’avance pour vos retours,
I try too to install /e/ on my fairphone, but i can’t receive the Bootloader Unlocking Code (Bootloader Unlocking Code for Fairphone 3 - Fairphone) despite the correct number of serie & IMEI
Could you help me ? Have you ever had this problem ? How can i unstall the /e/ on my fairphone ?
Thanks by advance for your feedback !
What exactly isn’t working for you?
Until then
 via the search function of the forum
Hi @AnotherElk and thanks for your return.
I have the same problem as :
I’ll try to find answers on this topic
