Hi all, a few days ago my FP2 started to prevent me answering to incoming call. When a call is coming in, the ringtone starts, but the dialer doens’t show any incoming calls. When the caller stops to call, soon after the dialer shows the missed incoming call. In this way I cannot answer, and currently I’m missing the 100% of incoming calls. My FP2 is updated to last October update, and all apps are updated too. I’m using two SIMS, and I’m facing the same effect on both SIMS. Any hints or suggestion? Thanks a lot
What sometimes happens (and I don’t think anyone has figured out why/how this happens yet), is that the permissions for the Phone app get changed. Take a look under settings > Apps > Phone (or Telephone), and check whether it has permission to show notifications - re-enable if necessary.
