Well, first of all, Fairphone is NOT a privacy phone by default. You can make it a privacy phone by installing a custom ROM with respective privacy features, but you can do that with nearly every other phone as well. And second - WhatsApp and privacy? Youāre kidding, arenāt you?
I didnt say WhatsApp was private, I said I use it extensivelyā¦
To install a ROM requires jailbreaking the device and potentially bricking it - hence my interest.
If you dont have an aswer thats fine, but log on to troll, reallyā¦
Sorry if I took you wrong, but my understanding of your question was, that you want to use Fairphone as a privacy phone. So my post was intended as an answer to this. And yes, I really think that using WhatsApp on a privacy phone isnāt a good idea. Trolling wasnāt ever my intention.
Unfortunately because of my work and travel and have few other options other than to use WhatsApp as it is the āgo toā for many.
That aside, the comms are more secure than 95% of the market, but I believe it tracks you on an ongoing basis and the backup isnt encrypted leaving the entire contents machine readable.
This is a dumb Q, but are there any other phones you know of that allow āsemi-normalā functionality and offer an escape from the Google ecosystem?
I checked your list with Aurora Store, an alternative Play Store Client which tells right away whether Apps are dependent on Google services to work.
You didnāt say which authenticator exactly, and I didnāt see the Nationwide App (might be region-specific), but banking Apps donāt like to run without Google services as a rule of thumb.
Minding this disclaimer, everything you list is dependent on Google services to work.
If these Apps would be a nice to have for you, Fairphone have a partnership with the e foundation, which brings their /e/ OS to the table. Itās focussed on getting Google stuff off the phone, while still being Android and providing an Open Source component mimicking Google Services to let many Google-dependent Apps work, but thereās no guarantee for 100% of the time or at all.
If you really rely on Google-dependent Apps to work 100% you might want to look into a Custom ROM like LineageOS in connection with Google services installers like Open GApps (letting you limit the amount of Google services and Apps on the phone at least), and Googleās device registration for the use of Google Apps and services on non-certified Android OSes (to not endanger your Google account with violating TOS) ā¦ https://www.google.com/android/uncertified/
The ones above are key to my work (I think I might be able to change WhatsApp for open source - will need to check), especially the banking apps as I rarely use online services when not working (I live behind a laptop so try to avoid it when not working).
Google - yuk! Hence why Iām looking for other options
Iāll look into Lineage OS, although I suspect it may be a little immature yet. It is so difficulkt for new players to get into the market and the big boys have every turn blocked so if I can find a way to support them I will!
The Fairphone 3 ships with Google Play Services and Android 10 so all these apps should work just fine. It is just a regular Google-approved Android OS, after all.
There is the custom ROM /e/OS which instead uses microG, which is an Open Source partial reimplementation of Google Play Services. I assume you are talking about this because you are talking about a privacy phone and worried some apps wonāt work. Fairphone supports installing different OSses and isnāt locked up to prevent that so thereās no jailbreaking involved: https://doc.e.foundation/devices/FP3/
On /e/OS, I can confirm WhatsApp works fine. The rest I havenāt tried. I do think however you would be better off asking about this on the /e/OS forum if you want to use /e/OS.
I use the app Shelter on my phone to keep the app whatsapp away from the rest of the phone, as I canāt persuade the family to go to Signal.
Downloading through the Aurora Store, Shelter or through F-Droid.
I think I understand your intention. You want get away from the big players and so of course google. My advice to you would be to go with https://e.foundation/ for the start, if it can cover your needs. And then you should also read more about security, privacyā¦ I can see a lack of knowledge, what isnāt something bad!
I can understand the others getting excited about whatsapp + privacy but it is really bad to just offend someone who may really donāt know that much. No one is born as techi.
The Apps which are key to @tosh124ās work might even work on /e/ at first, but due to the genuine Google services replaced with microG they might also fail to work at any given time due to changes in Google services.
And all /e/ can do about this then is shrugging their shoulders and update microG, how ever long this might take then.
This is no mere theory or fear-mongering, Iāve seen Google-dependent Apps fail for a while because of microG having to catch up with changes on Googleās side. Websites might be a workaround then, but not every App has a corresponding website usable on a smartphone, especially when it comes to banking.
I have gone with /e/ and spent yesterday rooting an s7 edge and Iām now trying to load it - keeps failing with error 7, which is seemingly something to do with an āAssertsā statement.
I have removed it and TWRP doesnt like the the recreated zip fileā¦
In summary I am dipping my toe into the water to see if I can use the OS on a day-to-day basis, it may be 100% and whilst I can compromise in some areas there are others I cannot - so the proof of the pudding is in the eating - well it is if I get the OS loaded
If it does so be it - Iāll use the phone as a second device - if I get lucky and the compromise isnt too great Iāll use it for my daily, either way its a win-win at the moment.
