I want as little Google as possible on my Fairphone 4!
…and when will Iodé be ready fpr FP4?
Only beta versions are on the Play Store, see the README for how to join the beta.
Or, since this is a topic about de-googling, you can install it via F-Droid too :smirk:
Florisboard lets you swipe across the spacebar to move the cursor around, which is a much more elegant solution than arrow buttons, and I really wish AnySoft implemented that feature.
Also in OpenBoard
Florisboard is not usable in german. at least not for me. because of dictionary and auto correction.
january at the earliest. but i expect at least february.
I don’t need a dictionary (it’s in my head!), but I need a Swiss German keyboard :wink:
you’ll have to try installing it and checking if it offers the layout you need.
Hi, thank you very much for the list.
How exactly did you uninstall them?
Because I haven’t rooted my fp4 yet (is there a way?) I cannot log in to root over adb.
Have you found a way to root it, or did you just disabled them from the settings?
Or am I missing something else?
@pseu
Try this:
adb pm uninstall --user 0 name.of.package
Thank you so much.
Works like a charm.
To also give something back, here is a one liner to execute in Linux (maybe also other UNIX-like, idk) systems to uninstall all the apps at once:
xargs -0 -n 1 adb uninstall --user 0 < <(tr \\n \\0 <apps.lst)
where apps.lst is just the copied list from Stanzi into a file (note that there need to be linebreaks in between the packages).
Did anyone had success using LineageOS 23 dialer? (https://www.apkmirror.com/apk/lineageos/lineage-os-phone/lineage-os-phone-23-0-release/lineage-os-phone-23-0-3-android-apk-download/download/)
My phone rings, but I can’t answer calls just rings with no permanent notification (I can make calls though) - and notifications are allowed for the app and it is set as default.
Solved by changing to Simple Dialer.
By any chance did you manage to remove the search box ?
Regards
Only by using a third Party launcher
With LawnChair in f-droid store…
Thanks to you and the previous answer,
Hoping this get solved in future update to allow us to remove it…
Unfortunately, I am running again into similar issues with android.intent.action.CREATE_DOCUMENT :thinking:
Mainly while exporting settings from apps (andOTP, AntennaPod…)
Anybody experiencing this as well? Any ideas what the issue might be?
EDIT: It seems, that a lot of App rely on the DocumentsUI app from Google and alternative file managers like Material Files cannot replace some of their function.
I had therefore to reinstall the original App using
adb shell cmd package install-existing com.google.android.documentsui
If you want to use backup functions of your apps you cannot remove this app from your phone. I’d be glad to be taught differently.
as indicated above this could be a general A11 issue, so did you read this https://www.reddit.com/r/Android/comments/j3zgmm/managing_files_in_the_androiddata_folder_on/
By any chance did you encounter DNS issue in 4G after removing theses packages ?
I currently do not have any DNS resolver when I’m in 4G,
Everything works perfectly in wifi
EDIT : Seems like there’s no default DNS server for 4G or something like that, using blokada VPN allow me to use 4G correctly ? I don’t really understand where the problem is
After a week of testing, my current list has 93 removals:
com.android.bips
com.android.bluetoothmidiservice
com.android.bookmarkprovider
com.android.carrierdefaultapp
com.android.chrome
com.android.companiondevicemanager
com.android.dreams.basic
com.android.dreams.phototable
com.android.egg
com.android.email.partnerprovider
com.android.htmlviewer
com.android.keychain
com.android.launcher3
com.android.mtp
com.android.providers.calendar
com.android.providers.partnerbookmarks
com.android.simappdialog
com.android.soundrecorder
com.android.stk
com.android.traceur
com.android.vending
com.android.wallpaper.livepicker
com.android.wallpapercropper
com.fairphone.myfairphone
com.fp.camera
com.google.android.apps.docs
com.google.android.apps.maps
com.google.android.apps.messaging
com.google.android.apps.photos
com.google.android.apps.restore
com.google.android.apps.setupwizard.searchselector
com.google.android.apps.tachyon
com.google.android.apps.wellbeing
com.google.android.apps.youtube.music
com.google.android.calculator
com.google.android.calendar
com.google.android.configupdater
com.google.android.contacts
com.google.android.deskclock
com.google.android.dialer
com.google.android.feedback
com.google.android.gm
com.google.android.gms.location.history
com.google.android.googlequicksearchbox
com.google.android.inputmethod.latin
com.google.android.keep
com.google.android.marvin.talkback
com.google.android.onetimeinitializer
com.google.android.overlay.gmsconfig.common
com.google.android.overlay.gmsconfig.gsa
com.google.android.overlay.gmsconfig.photos
com.google.android.overlay.modules.documentsui
com.google.android.overlay.modules.modulemetadata.forframework
com.google.android.partnersetup
com.google.android.printservice.recommendation
com.google.android.projection.gearhead
com.google.android.setupwizard
com.google.android.syncadapters.contacts
com.google.android.tag
com.google.android.tts
com.google.android.videos
com.google.android.youtube
com.orange.aura.oobe
com.orange.update
com.qti.confuridialer
com.qti.dpmserviceapp
com.qti.qualcomm.datastatusnotification
com.qti.service.colorservice
com.qti.snapdragon.qdcm_ff
com.qti.xdivert
com.qualcomm.atfwd
com.qualcomm.embms
com.qualcomm.location
com.qualcomm.qcrilmsgtunnel
com.qualcomm.qti.callfeaturessetting
com.qualcomm.qti.confdialer
com.qualcomm.qti.dynamicddsservice
com.qualcomm.qti.lpa
com.qualcomm.qti.qms.service.telemetry
com.qualcomm.qti.qms.service.trustzoneaccess
com.qualcomm.qti.remoteSimlockAuth
com.qualcomm.qti.uim
com.qualcomm.timeservice
com.qualcomm.uimremoteserver
com.qualcomm.wfd.service
de.telekom.tsc
org.codeaurora.ims
All working good!
