I cannot call with fp4
I canot Call with the fairphone 4. I need to restart the phone to make a call but in few minutes it stops again. I can call with whatsapp but i cannot do normal calls. What can i do?
Have you tried wi-fi calling in the states. This leads to less dropped calls in the USA . others may tell you otherwise. But i’m positive it uses mobile data as a fallback when set to use wi-fi calling on the road. At least in the states anyway. It could be different in Europe. Hope this tip helps you with your FP4
What exactly means, you
Which software, provider, network are you using?
Same here, since update yesterdag with LineAge OS
But ist looks like you are talking about a FP3:
