I’m not able to use it to unlock the screen.
Do you have some suggestion to best store and use the fingerprint digit?
Because I think the prob could be:
or I store bad the fingerprint digit
or I try to use it again bad
Any Idea?
TIA
Renato
Any Idea?
TIA
Renato
Hope this helps:
Sbloccare il telefono con l’impronta - Guida di Pixel Phone (google.com)
Best wishes,
Thomas
A few tips given by a forum member:
You should also try to turn your finger as much as possible on the fingerprint reader when saving it so that it recognizes fully your finger.
Otherwise, if you have a very low recognition rate, you may have a faulty sensor. Then you should contactsupport.
“maybe” I found the solution
I’ve found that the angle of finger-digit, is to much important.
maybe, the problem is this.
I’ve changed the hand with whom I store the finger prints.
And I’ve store (less or more)the position of my hand in the moment I made the finger print.
I thought that the position (angle) was non so important.
Renato
Record different parts of your finger: plain middle, slightly rotated to side, slightly shifted towards the tip…
Record the same finger several times in different conditions: normal, sweaty, in the cold…
The idea is to cover as many real-world situations as possible.
This topic was automatically closed after 182 days. New replies are no longer allowed.
