How to Transfer Data using a Cable from iPhone
Here are the steps I’ve been advised to follow:
  1. Turn on your new Fairphone and tap Start.
  2. Connect to a mobile network:
    • Insert a SIM card or tap Download a new eSIM.
    • Or tap Skip.
  3. Connect to Wi-Fi:
    • Tap your network name to connect.
    • Or tap Set up offline.
  4. To Copy apps & data, tap Next until you’re asked to find a cable.
    Tip: This is usually the cable used for charging.
  5. Insert the cable into your old iPhone, then tap Next.
Unfortunately after step 3 it doesn’t give me the option of clicking “Next until I’m asked to find a cable”…what do I do?
Maybe this link is of use? There appear to be more steps and other ways of copying data.
https://support.fairphone.com/hc/en-us/articles/27514270445202-Transferring-Data-from-iPhone-to-Your-New-Fairphone
Welcome to the forum.
Just to be clear, you’ll need a cable compatible with your iPhone (likely a Lightning plug) at one end and USB-C at the other.
Did you connect to Wi-Fi?
Do you mean that there’s no “Next” button? If there’s no “Next” button, could you post a photo of the Fairphone screen, or describe it?
Yes I have that cable, but unfortunately can’t even get to that stage as the following screen doesn’t come up. I can connect to a mobile network and wifi fine (steps 2 and 3).
“To Copy apps & data, tap Next until you’re asked to find a cable.”
wow, I wasn’t even aware this is possible nowadays….
Don’t wow too soon, maybe it’s not!
I’m hoping @tristanw can provide a photo of the FP screen, maybe using the iPhone.
There ought to be some option to continue, or skip whatever step is causing a problem.
