How to remove notification warning that emergency calls are not supported over wifi
Hi, I just started getting a notification again that emergency phone calls are not supported via wifi whenever I’m connected to wifi. I remember this being an issue when I first got the phone a few months ago I think but it went away by itself maybe?
I can’t remove the notification which is really irritating me since it’s static information that doesn’t change so why can’t I close it after having read it? I’d appreciate any help with this!
Hi, am I correct in assuming you’re using the FP6? What version do you have - Android or /e/OS?
Thats provider dependent and you cant turn it off as long as Wifi Calling is enabled.
Weird, I had it off when the notification first came so I tried turning wifi calling on to try and troubleshoot. Turning it off again did indeed remove the notification thanks!
