My current state:
Fairphone 3 with /e/OS installed is stuck in recovery mode, (I think) because there is not enough free memory space left. I need to erase some files from my Ubuntu 20.04 and I thought about using adb.
Problem:
I used disk encryption and now I don’t know how to access my data and where it is located. I can activate adb on my phone and access it from Ubuntu with adb shell command. For example if I run
adb shell
and then
FP3:/ # ls
acct d etc mnt plat_property_contexts prop.default sideload system_ext_property_contexts
apex data first_stage_ramdisk odm postinstall res storage tmp
bin data_mirror init odm_file_contexts proc root sys vendor
bugreports debug_ramdisk init.recovery.qcom.rc odm_property_contexts product sbin system vendor_file_contexts
cache default.prop linkerconfig oem product_file_contexts sdcard system_ext vendor_property_contexts
config dev metadata plat_file_contexts product_property_contexts sepolicy system_ext_file_contexts
When I then try to list the content of data/, storage or sdcard it shows an empty directory. How can I access my internal storage data?
