How-To: Install ADB driver and Tools and get Filesystem acces with adb in Total Commander
1. Install ADB Driver from Android
Please be aware, I force using a Driver which is not written for FP2.
Get the Driver from -> https://developer.android.com/studio/run/win-usb.html
Follow these Picture-Guide :de: :
2. Install ADB/Fastboot
Please Install ADB now: -> https://wiki.lineageos.org/adb_fastboot_guide.html
3. Filesystem Access
To get Filesystem access with the full power of a Graphical Command Manager use “Total Commander” for Linux you could use “Double Commander” (not tested)
https://www.ghisler.com/download.htm
Total Commander has great Plug-in ability. With the following Plug-in you could access the phone with ADB.
http://www.uniqtec.eu/applications/android-adb.html
For Total Commander (32 and/or 64 bit) copy the Zip from the [Windows x32] download and unzip it.
Include the Plugin into Total Commander
Now open Network and double-click ADB
For Linux there are some interesting projects for an adbfs.
See: https://github.com/search?utf8=✓&q=adbfs&type=
Thanks for your tutorial! Although I don’t need it myself, I will incorporate some useful bits of it into the FPOOS Fastboot guide.
