Always, when my FP3 connects with my car stereo via Bluetooth, Spotify starts immediately playing the last song. This is super-extreme annoying and there are dozens of complaints on their forum’s site.
So: how can I disable the Audio Resume Autoplay when connected via Bluetooth on my FP3 in the OS Settings? I currently don’t see any switch in my settings.
Thx for the suggestion. As I understand this article, it’s about installing some Tasker XDA application and do some playing around with it. Didn’t know of Tasker. I’ll give it a try.
Even as Tasker is set to grab Bluetooth Media Controls, Spotify starts playing when connected to my car Bluetooth. Well, it doesn’t immediately. But as soon as I switch to Spotify it starts playing even if I stopped playing previously.
I think this is - despite what they are saying - a real only Spotify only issue.
So, sorry for the noise, but I assume Fairphone OS can’t help this.
Reading through the link above, I would think its triggered by Android Car and Spotify has no option to interfere. I never used Android Car and have no idea if it’s useful for other things, but why not just disabling this App?
Android Car? Well no, this is very old Kenwood Radio in an even older VW Golf. Both from a time where nearly all handheld phones have been produced in Finnland, and they’ve been not very smart. This is a tech whose age is in the double-digits.
It’s just FP3, Spotify and a very, very basic old Kenwood Car HiFi radio.
Edit: you mean disabling Spotify? Why should I do that? I want to listen, but when I want, not when Spotify think I should.
Maybe the idea is that by disabling, not uninstalling you just have to enable it, or is that too much trouble? How many extra taps on the phone does it take to enable?
I can “Force Stop” or “Uninstall” Spotify. Both via Settings, which is quite a hassle, the former doesn’t help and the latter is out of the question. So both is too much trouble.
Then I just can stop Spotify from the running tasks, yes but a) why should I always before I sit in the car first check my phone, if it’s happy with this (again, this is too much trouble) and b) it doesn’t help either, since when Spotify is closed and when I’m in the car, as soon as I open Spotify, it immediately starts playing where I left it even if I stopped playing the song before.
All I want is Spotify to just do not start immediately when connected to a new Bluetooth device. Just the very same as Audible and DI.fm do on the very same device. Alas, they manage it, why not Spotify? Though Audible needed quite a user shitstorm to do it.
I meant to disable the Android Car App on the FP3 not your Car system. Its installed on the FP3 with the system and there, so if not needed, disable and see if this helps. I have it disabled on the FP2 and Spotify does not Autoplay
Ah! I found an “Android Auto” (every time I wondered what automatic tasks this thing controls or starts), but no “Android Car” on my FP3. Also, I thought Android Car is an Android installed on the car media devices, not on my phone. Obviously a misconception…
Report after some tests: well, something has changed. Spotify does not auto-magically start playing when my FP3 connects to my car … sometimes. Sometimes it still does. Hard to deterministically reproduce. I’m still to find a recipe for how to trigger this effect with 100% chance.
I’m somehow lost.
Ok, I’m now thinking of making a factory reset. Perhaps I also play around with some alternative OS (Lineage coming to mind).
Sounds a bit radical for the problem you’ve outlined.
Yes, this looks like a Spotify problem.
I was about to make the same suggestion as Yvonne about background running but that’s already been discussed above and seemingly rejected…
So I guess Spotify need to prepare for a similar storm from at least one user
Or else … dare I say it, choose a music player that does what you want, not what they think you want.
[Edit] - P.S. are you sure you’ve been thoroughly through the Spotify settings to make sure you can’t turn off this behaviour? I agree it’s very invasive. I don’t use this app and I’m not doing the work for you, but I find it difficult to believe that you’re the only one who wants Spotify to shut up.
Yes, this sounds like a solution. Yet I’m very often listening to Spotify and I have to get into the habit of checking my background apps on the FP3 before I get into my car. Which - sounds a bit odd - “Hey, let’s drive to McDonalds!” - “Sure, just check my phone for Spotify.” - “Wait! What? Why?”
Wouldn’t life be boring if everything was perfect …
But if you accept the background apps idea, you want to swipe out Spotify when you finish listening rather than every time you get in the car.
Removing unnecessary background apps will also save you some power usage.
Yes, I do think, the main culprit here is Spotify and, yes, factory resetting my phone, is harsh. But then, I do have other issues too. Maybe there’s a bundle of quirks already and Spotify just tips it.
And… hahaha, there’s already a lot of this issue over on the Spotify forums about this. But Spotify customer care is … uhm … “improveable”. I have the impression, they just a give a s…t about users.
Now, the Spotify feature, all this music, is something I cannot miss. Recently Spotify sent me my yearly usage summary listening over 80.000 minutes of music listening (sic!) for myself. A bit creepy too, since I think, they very well do some heavy analytics on my music consumption too, which they wont show. At least to me.
But: I.simply.need.music.
The alternatives to this is from other big tech like Amazon, Apple, etc. which gives me even more shivers. Spotify seems to be the least evil here. But I’m starting rethinking…
Are there any alternatives out there - which can be trusted?
I really doubt a factory reset will change the Spotify behavior, because last week I had the same happening, which made me think of the background running. I’m used to close apps, but at that time I did not. Its the same on my company IPhone, when the app is not closed, it will start playing. Irrespective of which car I drive.
