How to deactivate Clipboard overlay FP3+?
Would it be possible to deactivate clipboard overlay on my FP3,
I searched the parameters and tried different command via adb but without success.
Even changing for anysoftKeyboard does not deactivate this overlay pop up window.
any idea ?
Thanks, patrick
What is clipboard overlay?
Could you provide a screenshot to show it?
Hi Elk,
After copying data, for example in Message appli, the system displays a pop-up window with the content of the copied data. This is very annoying to me.
Here an example :
Thanks for your help,
patrick
I can’t verify at the moment, but worth trying … https://www.reddit.com/r/AndroidQuestions/comments/195n34y/clipboard_popup_android_14/
Hi Elk,
Thanks for this info.
I tried the solution and it works quite good.
Many thanks for your help,
patrick.
