Question from Hielke:
How to block a particular phone number when you want to prevent someone from calling you?
Answer from @Lidwien:
This is only possible for numbers stored in your contacts (so if it isn’t already in your contact list you will need to add it first)
- Go to the ‘People’ app.
- Go to the contact you want to block
- Tap on it and then go to the settings button at the bottom left below on your phone
- Tap the option to “Block incoming calls direct”
Addition from Toon:
It will show six possibilities after tapping far left below.
[The to block number must be on your phone memory. If necessary copy the number from sim/sd-card to the phone.]
This question was originally placed on the old forum.
