How can you delete Sound Recordings no longer needed?
On Fairphone 2, where can you DELETE the Sound Recordings no longer needed? Jenny
I don’t know where they are stored exactly, but somewhere in your internal storage (which you can access by going to settings > storage > internal storage > explore) there should be a folder (probably called ā€œsoundsā€ or ā€œrecordingsā€ or sth) which contains the audio files. Then just long press on the file and hit delete :slight_smile:
Thank you Stanzi, the ā€˜long press’ worked! Jenny :slight_smile:
