I would like to add a new tile to the notification drawer (the one you pull down from the top) to temporarily disable my lockscreen.
I know that CyanogenMod provides the feature to modify the notification drawer. Is something similar possible with the default Android version installed on the Fairphone?
Thatâs not the reply you expect, but there is a paying app named Skiplock thatâll allow to auto-disable the lockscreen when âfeelingâ wifis or other features whose presence means you are in a safe place.
This app features a drawer notification which, when displayed and clicked, toggles the lock IIRC.
There are also a range of other alternatives in this area; I chose Skiplock against others because it seems the only one to control the âdrawingâ lock (others only handle lock codes)
H.
Yeah, you can use âGravityBoxâ which needs the âXposedFrameworkâ, see XDA-Forum.
For me it is working like a charm, but thanks to its huge possibilites one should read a little bit how to use it in advance!
Cheers, Robert
