Hi I want to remove “hey Google” widget on home? Is it possible? How?
Signal have alwayse background notification status, can I remove its?
Thank you
Thank you
Either by installing a different launcher … for some inspiration see Android 7 Nougat / 8 Oreo / 9 Pie: Home screens / Launchers.
Or by enabling USB debugging, and then using ADB to uninstall the search box for the current user …
adb shell pm uninstall --user 0 com.google.android.googlequicksearchbox
Thank you, now There is “find” box, Can I remove it?
So there’s still a box?
Edit: Ah, I’ve seen this here too late …
A different launcher it is, then.
