This is not a reply to the question but a comment/question releated to FP2 contacts. It seems that after the last update a good part of my contacts are hidden somewhere. I can not find them from the contacts/addressbook any more. But when one of these “hidden contacts” calls me I can see his/her name on the screen. Hence the contact data is still somewhere - as it should - but somehow I can not find it. Any simple advice?
Check this option:
Open the contacts app
go to the menu in the upper right corner (…)
Choose the ‘contacts to display’ entry
I guess you have several accounts with contacts?
