Headband Base weak plastic?
Thanks for spotting it, i didn’t saw it in this long thread.
I already received the message that my warranty was expired (well, not a real surprise)
I will re create another ticket, again… pointing to this message and my previous order for the replacement.
I am disappointed, because i used to recommend that brand.
Let’s see if I’ll have a positive feedback…
Thanks,
D.
Hi all,
Well its my turn to complain about this issue and also to extremely slow support response time.
i bought mine the 15 june 2026 and it snapped arround the 10 january, will i just took it off like usual. So not even 6 month.
It took them 10 days to put me on “Pending request” and now its 1 month and still no news. Thats not acceptable to have an headband base as a “consumable” especially for what should be a durable product. The cheap xbox headphone lasted me longer than that and at some point it will be cheaper for me to by a throw away those kind of headphone than buying a base twice a year.
i’m really disappointed. My fairphone 3 lasted me 5 years and the fairbud XL not even 6 month. I guess i will have to throw it away when the warranty is reached… if they send me the replacement part one day
And the support just send me an email 24h after my previous post.
I bought some replacement headbands with the £50 voucher they gave out last year and one of them has snapped already. Opened a ticket for it, seems like the part I got is officially part of the 2025 refresh design (though it fits the 2023 ones perfectly). Seems like this is still an issue. At this point, they would be better offering metal ones as a replacement, or use sturdier plastic for this one part, even if it isn’t recycled.
The day has come.
Mine’s headband has snapped too. Rip in pepperoni.
RIP? You can easily fix this. Also, contact support, they may refund you the cost for the part.
I mean, DUH, yes its a fairphone product. I can get a replacement part and bobs your uncle.
It just (vaccuum) that it happened. Good tip on the support bit though. I’ll go check.
Hi, After changing the part twice i am trying a diy solution, with a more sturdy part…
Will do the same now, it’s already the second pair. Are you using PLA?
I printed my replacements in PLA and they already last for quite a while now.
