Has anyone been able to activate an eSIM?
In the vague hope that I’d misdiagnosed the undermentioned:
…I’ve attempted to convert my physical (nano)SIM to an eSIM:
  1. #!/system/bin/sh
    cmd activity start --user 0 -a android.intent.action.VIEW -n com.android.settings/com.android.settings.Settings$MobileNetworkListActivity -f 0 com.android.settings
  2. That brings me to com.google.android.euicc/com.android.euicc.ui.activation.QrDownloadActivity, where the value provided by my carrier appears to fail to authenticate:
To ensure that this is a fault of my carrier, has anyone else managed to activate an eSIM on FPOS? If so, are you able to provide the build number that was successful?
Yes I have more than one. An eSIM for travel and recently from a German provider. No issues at all.
@yvmuell, did you activate them via that process, or via initial importation?
@rokejulianlockhart i have used three eSIMs on my FP5. In two cases I have purchased them as eSIM directly and received the installation instructions.
In one case I switched and had to communicate with a provider, can look for details if you need that cause I don’t remember whether I needed to see them in person. I think they had to deactivate my previous physical SIM card.
Thanks, although I imagine it’s not applicable here, for SMARTY explicitly offers this as a switch option, wherein the old, physical SIM shall be automatically deactivated.
If you find anything useful, I’ll still be glad to hear it, though. I’ve asked elsewhere, too:
which process? I changed my SIM to eSIM in the FP4 and needed a new eSIM when changing to FP5 recently, however the process to add it, does not differ. The travel SIM was new and directly an eSIM, I used and added that in Nov 23. Overall there are many people using dual SIM, so I assume its rather an issue with SMARTY in general or the SIM, I doubt its OS Version related.
@yvmuell, thanks. That’s what I meant.
