I thought that basic users “can use all core Discourse functions”…
Unfortunately I experience the same problem:
- GPS gets switched on after I switch on Mobile Data
- FP1U
- using only one SIM card
- Austrian network provider Drei
- first occurred around Jan 15th 2017
- I did not install any new apps for several weeks before this started
- but I regulary update the installed apps (could therefore be an update issue; but it seems the problem occurs only in Austria? So maybe not)
- two days after the problem started, I switched off every GPS permission I could find in the Settings, but it did not solve the problem (and I have been using the FP since 2014 with several permissions for apps active without GPS problems before)
- the problem occurs even when I close all apps before I switch on Mobile Data (though I noticed that in Settings / Apps / Running I can still find a few apps running, like Fairphone updater, various Google apps like Playm Google Services etc., Battery warning, Telegram, Contacts, but no apps I would expect to use GPS data)
Hope this can be solved soon…
Thanks,
Katharina
If one of you attends our next Austrian Fairphoners meetup we can do some debugging. It sounds as if this was easily reproducible.
I experienced the same on my FP2. I checked in the location settings and found out that the “dialer” app - the phone app itself - was the culprit. This felt very dodgy to me, because I had a sense someone wants to track me. I was probably right with this assumption, and the “someone” being “the usual one” - means Google, because since I am using a completely Google free phone - FP Open, no GAPPs installed, I have not experienced that again.
Hi there - I have the same problem (also Drei AT and FP1)
It’s even worse with me because GPS automatically switches on when I just make a phone call.
Have to switch it off manually all the time.
@Rene_Sendlhofer has opened a bug report (Thank you!):
https://forum.fairphone.com/t/fp1-gps-activates-itself-when-mobile-data-connection-is-active/25541?source_topic_id=25418Let’s collect all we know about this in the wiki post you can find there (not editable by new users).
Thanks for the link but it says thread closed a couple of minutes ago.
Wiki posts can be edited after the topic has been closed.
thanks - looks like I am classified new user level 0. Can’t do anything.
Would really love to help with information.
I gave you Level 1!
thanks
still can’t write anything there though.
You are temporarily Level 3 now.
This is probably because the call is routed over 3G. If you want to verify this, you can disable 3G by going to Settings > [Wireless & Networks] More… > Mobile Networks > 3G > Enable 3G > Off. Obviously, you’ll want to re-enable this after testing if you ever use mobile data.
As for this suddenly appearing: It could be that Drei has starting using their frequencies in a different manner than they were doing before. As said, I can’t figure out what the exact problem is, and as I’m not experiencing the same issue, I can’t really help beyond this…
thanks. Nop, still there.
Even rang 3 - they say it’s definitively not them. They blame the satelite - unfortunately they don’t have their contact details
I have the same problem with my FP1. GPS turns on automatically although all GPS settings are turned off.
I also use it with the Austian provider Drei and the problem occured first last week on January, 18th.
I hope there will be a solution soon.
Eva
just learned from neighbour that he has it too - but he is with telering
So it’s not just my phone!
I have the same problem with the GPS on my FP1, since about ten days. I’m also with Drei in Austria, and I have all access to GPS turned off on the phone, in settings, in camera, on all apps where possible, and the time is set to network not GPS.
Still whenever I access my network internet, the GPS turns itself on and stays on until I manually turn it off.
I haven’t recently added any apps, but I did disable Google news.
would love to hear if there is a solution to this!
many thanks,
Rebekah
I’ve added in some details based on what’s written here. I’m not sure what debug info would be useful (and I cannot provide any data as I’m not an affected network).
If what I gather here is correct, namely that the phone starts to determine the location even when the use of GPS satellites is disabled in settings > location access, we can rule out regular apps as iirc you need system privileges to change that.
On October I had to hard reset the FP1 then from this point to now GPS starts automatically, not only when I try to make a call, often when it’s in my pocket, I take it and I check it if it’s active and then sometimes I must disable it.
I live in Italy and I have Wind Telecomunicazioni SpA as provider.
WIND: MCC 222, MNC 88
3 Italia: MCC 222, MNC 99
Wind and 3 in Italy are implementing a merge of their societies…
I’ve contacted support and will report here, as soon as I get an answer.
