🇫🇷 Problèmes un charge
Hi i juste bought a fairphone few dans ago, and it seems that i can’t use it when he is charging. Is that normal? Is there a way to change that, in the settings maybe?
Thanks
No. The normal behaviour would be that you can use your FP2 also while charging. Try it with different chargers or with connecting to the PC and look if that works.
No. It is not intended that you can’t use your FP2 while charging, so there is no switch. A “make phone useless while charging” switch would not make sense as nobody wants such a “feature”.
There are more people with this problem, read fairphone 2 unusable while charging.
Thanks i’ll try that.
If you’re good with english and have further questions please continue there. If you need advice in french you can continue here within 2 days.
I set this topic to close in 48 hours after the last reply.
