FP6 Unofficial LineageOS 23
Thank you for clarifying! Sorry for all the confusion, does android_packages_apps_AlertSlider already handle some of the moments switch functionality? I found parts · a15 · e / devices / android_device_fairphone_FP6 · GitLab and was going to use it as a starting point, but I’m unsure if I’ll add it alongside AlertSlider or if AlertSlider is doing some of that already.
I get this error when following the build instructions
FAILED: out/soong/build.lineage_FP6.ninja
cd "$(dirname "out/host/linux-x86/bin/soong_build")" && BUILDER="$PWD/$(basename "out/host/linux-x86/bin/soong_build")" && cd
/ && env -i  "$BUILDER"     --top "$TOP"     --soong_out "out/soong"     --out "out"     --soong_variables out/soong/soong.lin
eage_FP6.variables -o out/soong/build.lineage_FP6.ninja --kati_suffix -lineage_FP6 -l out/.module_paths/Android.bp.list --avai
lable_env out/soong/soong.environment.available --used_env out/soong/soong.environment.used.lineage_FP6.build Android.bp
Warning: Module 'webview' depends on non-existing optional_uses_libs 'com.android.extensions.xr'
Warning: Module 'androidx.test.uiautomator_uiautomator' depends on non-existing optional_uses_libs 'com.android.extensions.xr'
Warning: Module 'androidx.wear_wear' depends on non-existing optional_uses_libs 'wear-sdk'
Warning: Module 'androidx.wear.compose_compose-foundation' depends on non-existing optional_uses_libs 'wear-sdk'
Warning: Module 'androidx.wear.watchface_watchface-complications-data' depends on non-existing optional_uses_libs 'wear-sdk'
Warning: Module 'androidx.wear.watchface_watchface-complications-data-source' depends on non-existing optional_uses_libs 'wear
-sdk'
Warning: Module 'androidx.wear.watchface_watchface' depends on non-existing optional_uses_libs 'wear-sdk'
error: vendor/fairphone/FP6/Android.bp:25328:1: module "libwfdservice" variant "android_arm64_armv8-a-branchprot_kryo_static":
 depends on multiple versions of the same aidl_interface: android.media.audio.common.types-V2-cpp-source, android.media.audio.
common.types-V4-cpp-source
 Dependency path:
           via tag cc.libraryDependencyTag: { Kind:sharedLibraryDependency Order:normalLibraryDependency wholeStatic:false ree
xportFlags:false explicitlyVersioned:false explicitlyImpl:false dataLib:false ndk:false staticUnwinder:false makeSuffix: skipA
pexAllowedDependenciesCheck:false excludeInApex:false excludeInNonApex:false unexportedSymbols:false}
    -> libwfdsinksm{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared}
    -> libwfdrtsp{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared}
    -> libwfdcommonutils{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared}
    -> libheif{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared,cfi:cfi}
    -> libmedia{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared,cfi:cfi}
           via tag cc.dependencyTag: { name:reuse objects}
    -> libmedia{os:android,arch:arm64_armv8-a-branchprot_kryo,link:static,cfi:cfi}
    -> android.media.audio.common.types-V4-cpp{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared}
    -> android.media.audio.common.types-V4-cpp{os:android,arch:arm64_armv8-a-branchprot_kryo,link:static}
           via tag cc.dependencyTag: { name:gen source}
    -> android.media.audio.common.types-V4-cpp-source{}
 Dependency path:
           via tag cc.dependencyTag: { name:gen header export}
 Dependency path:
 Dependency path:
 Dependency path:
xportFlags:true explicitlyVersioned:false explicitlyImpl:false dataLib:false ndk:false staticUnwinder:false makeSuffix: skipAp
    -> libaudioclient{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared,cfi:cfi}
    -> libaudioclient{os:android,arch:arm64_armv8-a-branchprot_kryo,link:static,cfi:cfi}
           via tag cc.libraryDependencyTag: { Kind:headerLibraryDependency Order:normalLibraryDependency wholeStatic:false ree
    -> libaudioclient_headers{os:android,arch:arm64_armv8-a-branchprot_kryo,cfi:cfi}
    -> libaudiofoundation_headers{os:android,arch:arm64_armv8-a-branchprot_kryo,cfi:cfi}
           via tag cc.libraryDependencyTag: { Kind:staticLibraryDependency Order:normalLibraryDependency wholeStatic:false ree
    -> android.media.audio.common.types-V4-cpp{os:android,arch:arm64_armv8-a-branchprot_kryo,link:static,cfi:cfi}
 Dependency path:
 Dependency path:
    -> android.media.audio.common.types-V2-cpp{os:android,arch:arm64_armv8-a-branchprot_kryo,link:shared}
    -> android.media.audio.common.types-V2-cpp{os:android,arch:arm64_armv8-a-branchprot_kryo,link:static}
    -> android.media.audio.common.types-V2-cpp-source{}
 Dependency path:
 Dependency path:
 Dependency path:
07:53:41 soong bootstrap failed with: exit status 1
The app you linked seems to be the implementation used on e/os. The alert slider app is doing the same on current lineage builds.
this sounds like you followed step 3 but not step 4. You can either skip both and use my provided vendor repository or fully regenerate it yourself, but that includes updating the WFD blobs.
That’s the outcome after doing both steps 3 and 4
The port number on <remote fetch="https://git.mainlining.org:4567" name="mainlining" revision="lineage-23.0" clone-depth="1" /> breaks repo sync
Well, then step 4 didn’t run. I fixed the step, it included –common-only which is an unrecognized argument and thus it didn’t run and immediately exited. If you haven’t tried that on your own, try that.
Got this using your vendor
-sdk'
Killed
08:35:26 soong bootstrap failed with: exit status 1
ninja: build stopped: subcommand failed.
Sounds like you’re running out of ram, unless you killed it manually. You can try to decrease the threads (for example add -n 4 to the command) or add zram/swap.
Hey !
On LineageOS, Is VVM available or not? Specifically on this ROM for the FP6?
As far as i know this should be working on any modern android version. My carrier doesn’t support it though, so i can’t verify that.
It does look like I’m running out of ram, I have 32GB though so don’t know why. -n is not a flag though neither is -j
sorry, yes i meant -j. You should be able to pass it to make bacon. Run breakfast FP6 before and it should result in the same.
There are reports about charging power beeing to high and therefore damaging the phone: https://forum.fairphone.com/t/my-fairphone-6-died-suddenly/123610
Does anyone know if this issue is also present in LOS or not?
I wanted to pop in just for a short thank you and positive feedback for a more or less smooth installation process. It was my first time trying lineage OS and that is what I am writing this message on.
Looking forward to more updates, like when this becomes fully open source and officially supported by Lineage OS. Thank you again very much.
Hi there,
First, thanks a lot for maintaining LineageOS for the FP6.
My question: do you have any idea when LineageOS will officially be supported for the FP6? And when it will happen, will we have to install it manually (maybe with deleting all data)?
Is it easier to install e/OS for now? I mean, is LineageOS perfectly working and stable even is non officially supported?
Thanks for your time!
Hey !
I see on your OTA repo that you published 23.1 for poco device.
Are you planning to do the same for FP6? Builds even if the version is unstable, as with 23.0 ^^.
Hi! I’m just commenting to say that i too would be very much interested in an official build for LineageOs. e os is unfortunately incompatible with too many apps i use who needs google play services.
Hi, i’ve just uploaded a new builds of LineageOS 23.1 (based on QPR1, with all the fancy new design). Since google just released the source code some days ago and all our features had to be rebased on this there could be some new bugs here and there, but overall it should be in a decent shape already, just so you know.
It’s also possible to lock the bootloader on Lineage now, but please only do that if you know what you are doing and have a reason to prefer a locked bootloader.
In order to lock the bootloader install lineage as usual, make sure that it boots to the system and then download this file: https://github.com/arian-ota/ota/releases/download/23.1-FP6-86664aae/pkmd.bin
Then, reboot to bootloader and run the following command to verify that you would be able to unlock the bootloader again in case of unexpected problems:
fastboot flashing get_unlock_ability
Then, set your phone up to trust my signing keys:
fastboot flash avb_custom_key pkmd.bin
and lock the bootloader:
fastboot flashing lock
Self builders can find instructions on how to lock the bootloader on their own builds here: Locking the bootloader · ArianK16a/android_device_fairphone_FP6 Wiki · GitHub
Please also note that you should never, under no circumstances, use adb remount while your bootloader is locked. Of course you should also not install any mods, whether it is magisk or google apps. If you need Google apps, build the rom yourself with them included and lock the bootloader with your own keys.
Is there a recommended gapps zip for 23.1 yet? MindTheGapps for android 16 doesn’t seem to work (the apps don’t appear) and the latest NikGapps results in an unbootable system
