FP6+ and lineage OS
I there, is it possible to install LineageOS for FP6 on FP6+ ?
I don’t know if the hardware is the same.
Thanks
The LineageOS team usually emphasizes that, unless explicitly stated otherwise, a firmware release is compatible exclusively with its corresponding model.
Therefore, I infer that the release for the Fairphone 6 should not be compatible with the 6+. It is worth noting that these are two models with different processors, so there should be no compatibility whatsoever.
There is a dedicated topic to lineage OS. I don’t follow it but someone posted that they installed it on FP6+, perhaps you can check with the Developer directly?
FP6 and FP6 + are now running on the same software in terms of FP OS so I am not sure how much difference the updated processor makes.
Thank you for the answer
Have a nice day
Yes, you can. You may notice that your model number is FP6, so the installation instructions on the lineage wiki all match.
Note that support is not official yet, but I can unofficially confirm that it works. Since the bootloader stats unlocked, risks are limited anyways.
I have been using iodeOS (which is based on lineage) on my plus since it came out, no issues.
If you choose to install lineage to your plus, you can help make it official. Message me here with your results, specifically checking if the 12GB ram are detected too. It’ll help validate the pending wiki change.
thanks a lot I will try
best regards
