I have a small “problem” with my Fairphone 5:
The power button (switch display on/off) can only be pressed well in the middle. If I press too far up or down, it works very unreliably (display does not react). The “pressure point” is noticeable everywhere. So I have to hit the middle pretty precisely, which is not always easy, to turn the display on or off.
That can’t be normal, can it?
Before I contact the support, I wanted to ask how it looks like for the other Fairphone 5 owners: Can you press the power button equally well everywhere? So does it work relatively far up and down as well as in the middle?
If yes, I probably have a hardware defect.
Thanks for your answers!
