FP5 not loading in car or pc
Dear Fairphone community,
Since some months I can’t load my FP5 in the car or on a laptop. It starts (recognises the cable) but stops after one second again. This is with different cars, cables and laptops so my assumption is, its the phone.
Android auto works via WLAN/Bluetooth, but the battery is draining obviously.
I tried different options like USB debug mode, only loading etc. Nothing worked yet.
Does anyone has an idea?
My specs: FP5 256/8gb
Running the latest FP OS on android 14
Build: FP5.UT2K.B.098.20250109
Cheers!
Afaik, as soon as a USB2-data-connection is established (like with Android Auto or a laptop), most phones limit charging to 500mA, because that’s the limit for USB2-ports according to the official specs.
You could mitigate that in some cases by using a USB3 cable in a USB3-connector. That should raise the limit to 900mA.
Hi Switch,
thank you for the idea! I have at least two USB 3 cable under the tested ones. Its the same issue. I would not even mind if its loading slower. But it is not loading at all :face_with_diagonal_mouth:
Anyone has another idea?
I have the same problem, my phone is 6 months old. Android auto was working but then, after 2 months, it is no longer recognized :cry: I tried with different cables or computers without success. The support of my store is really slow and for the moment, only the usb-c port has been changed without success.
