My fp5 is not charging properly.
I think there is a problem with the USB-C port because the charger cable will not sit easily in the port and keeps falling out. It also is charging very very slowly when I do get the cable seated just right. Has anyone seen this before?
I plan to replace the USB-C port component but before I spend the money I wanted to see if anyone has seen this issue before or anything similar?
Kind regards
Danny
